Wow that seemed to happen really quickly. Looking forward to the Chicago to Miami corrider to complete. All we need is Knoxville and either Louisville or Cincinatti to complete the route from the upper Midwest down to FL.
Any one have an idea if I would make it from this supercharger (London,KY) to Pigeon Forge,TN? It's about 132 Miles but not sure how elevation would change it. I have 85kw battery. Any input would be great! Making a trip from Chicago, thats my only concern.
Does anyone know if Chattanooga to London if possible with out a charge in between? I have a p85It would be really hard to not make it 132 miles on an 85kWh battery. My absolute worst range in my P85 was something like 185 miles, at ~80+MPH, some through the mountains uphill. As a general measure I use 200 miles as the meter for what is easily doable in normal conditions without question with an 85kWh pack.
This is easily possible. It's only 207 miles. Start from Chattanooga with a full battery and maintain a reasonable speed 65-70 and you should be good to go even without a CHAdeMo adapter or Level 2 stopping.Does anyone know if Chattanooga to London if possible with out a charge in between? I have a p85
Making a trip down from Chicago and charging here. Anyone have an idea if I would make it from here (london,ky) to Pigeon Forge TN??? I have an S 85 fully charge gets me 270 miles.
Use EV Trip Planner. Its predictions are very good, if you put in all the parameters. The distance is only 131 miles and 143 rated miles using standard conditions. If you can charge in Pigeon Forge when you get there, it should be easy.
