There are no impacts or closures from the Washburn fire in Oakhurst proper.Has anyone charged here successfully in the last week since the Washburn fire ?
Thank you
No. Was your battery cold?do they throttle power on weekend or at various times?
This is the most likely explanation - gets cold around there at night.No. Was your battery cold?
Well, it had done pre-conditioning for 25 minutes prior to arrival, and was at 12% SOC at arrival. When I arrived there was one other Tesla, after I moved three times I asked them if they had trouble getting power and they were getting 50 kWh but at higher SOC at the time.No. Was your battery cold?
I doubt that. Isn't the preconditioning system dumping about 6-8 kW worth of heat into the battery when it's running?Honestly that’s not nearly enough time for a fully cold battery that has been sitting all night.
You make a good point though for people staying in Oakhurst. If you have enough range to make it up to Fish Camp on your way to the park, you should absolutely charge there vs. Oakhurst. Particularly if your car has been sitting all night. The 600-700 wh/mi you burn to get up the hill will heat the battery much more effectively than preconditioning.
You really think 25 min of driving pre-conditioning and 15 minutes of actually charging wouldn’t be enough to bring battery temp high enough to get more than 45-50 kWh at a Version 3 SC?Honestly that’s not nearly enough time for a fully cold battery that has been sitting all night.
I don't think these cars use resistive heaters. They either run the motors inefficiently or use the compressor or heat pump or some combination of the above.Depends on the config of the specific car of course, but from what I’ve seen the resistive heating elements use about 4-5kw at full tilt. So yeah, practically speaking I don’t think that’s enough time to get a ~1200 pound battery in the 40s/50s to north of 110 degrees where modern firmwares want the cells to be for max charging rate.
Yes, was driving the entire time, maybe 3 min sitting. Just south of the main gate.Where were you driving from for those 25 minutes?
Of course it’s “possible” the station was having issues. That said, I’ve charged there probably 75 times at this point, at all times of the day and night, and never had an anomalous experience. It’s getting cold here in the mornings. It’s my experience most people vastly overestimate the effect of preconditioning. So…
So again, what you mean by "these cars" is relevant. My 2016 Model S most definitely uses a resistive heater. As do early Model Ys and Model 3s before ~2020.I don't think these cars use resistive heaters. They either run the motors inefficiently or use the compressor or heat pump or some combination of the above.
So you were driving down SR41 south into Oakhurst on a cool morning?Yes, was driving the entire time, maybe 3 min sitting. Just south of the main gate.
The Thursday prior I was there, had 250+ for up to nearly 30% SOC.
It uses a resistive heater to heat the cabin. The superbottle system uses only the motors to heat the batteries. There's no way to get heat from the PTC heater to go to the batteries.So again, what you mean by "these cars" is relevant. My 2016 Model S most definitely uses a resistive heater. As do early Model Ys and Model 3s before ~2020.
Not really. It's not "waste heat" from the motors as much as it is INTENTIONAL heat. It intentionally "stalls" the motor to overheat the stators and then uses the coolant to remove the heat that it (intentionally) created and deliver it to the battery. Bjørn saw the stators reach 55°C with the car sitting still.That's best case for preconditioning... the heat pump and/or waste heat from the motors is going to produce far far less.
I have all the same questions - especially the specific car you have.So you were driving down SR41 south into Oakhurst on a cool morning?
That's basically coasting, not drawing any significant energy from the battery for propulsion... nothing that would heat the battery in any significant way. In fact my wh/mi is usually negative between Fish Camp and Oakhurst.
What year/model/config car do you have?
This is true for the 3/Y, but S/X prior to 2021 have a dedicated battery coolant heater. So again... details matter here.It uses a resistive heater to heat the cabin. The superbottle system uses only the motors to heat the batteries. There's no way to get heat from the PTC heater to go to the batteries.
