Supercharger Stall Status now visible!
Discussion in 'Canada Supercharger locations' started by hingisfan, Feb 9, 2017.
Tags:
  1. hingisfan
    hingisfan hingisfan_Mark_V
    Kingston, Ontario
    Awesome!
  2. BerTX
    BerTX Supporting Member
    Texas/Washington
  3. Drone Flyer
    Drone Flyer Active Member
    Canada
    I noticed this too and it works great in Canada, not so much in the States. Perhaps a lot of them south of the border have older SC'ers and may or may not be able to be updated.
    Great feature though. I like the fact I can choose whether to charge at a certain SC or move on to the next one.
    Lawrence SC in Toronto is always never a good choice thanks to the service people charging customers cars there. This will have to stop soon though!
  4. BerTX
    Texas/Washington
    It only works within a certain, as yet undefined, distance from your car (approximately 400-500 km).
  5. Drone Flyer
    Canada
    Yes, I've since discovered that. It works to the distance you have range for.
  6. wayner
    wayner Active Member
    Toronto
    Someone has now made this info available on the web, check out the Model S UI forum.
  7. mknox
    mknox Well-Known Member
    Toronto, ON
    When I looked at this a week or so ago, it was showing me the number of open stalls AND what the Idle Fees were. Now I noticed the line with the Idle Fee charge is gone.
  8. SmartElectric
    SmartElectric Active Member
    Toronto,Canada
    We used the Port Hope supercharger this week and noted the screen said 3 of 8 stalls available. The data was incorrect due to maintenance.
    When we arrived, the maintenance crew onsite advised only one stall worked and we charged on that with only 40 kW of power. I left a note on plugshare. I wish others would do the same...
  9. mrElbe
    mrElbe Active Member
    Stouffville, ON Canada
    So the title "Hope of good Port" is still appropriate for that charger.
    • Funny x 2
  10. Drone Flyer
    Canada
    Yes!
  11. mknox
    Toronto, ON
    Interesting. I wonder how Tesla gets their availability data? I assumed it was coming in real-time from the Superchargers themselves. Perhaps all Tesla can see are how many cars are currently charging at the site, then just subtract that number from the known number of stalls.
  12. dhcp
    dhcp Member
    San Mateo, CA
    It seems to be about a 5 minute update interval - I pulled into one that said "1 available" so I plugged in and started a time and it was almost exactly 5 minutes before it said "zero available".
  13. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Pretty sure Tesla only has a data connection when a car is connected.
  14. Drone Flyer
    Canada
    If only there was a way they could tell if ICE cars are parked there too!
    They should put a compartment filled with ICE "Infraction" tickets on site so we can ticket offending cars as well as Teslas not plugged in!
  15. Willy3988
    Willy3988 Member
    Pleasanton Ca
    Was on my way to Manteca to charge this evening around 8:30 Map says it was about half full. When I arrived there were only 3 cars charging . Map said at that time only one stall was available. Not a super reliable indicator.
  16. sammyfan711
    sammyfan711 Member
    Downers Grove, IL
    I’ve noticed this as well - I think it is like 20-30 min behind real time updates
  17. TaoJones
    TaoJones Beyond Driven
    The Americas
    Hopefully they implement the feature request to add more value to the bars that used to be listed (red/grey). By changing those to red/yellow/green/grey, relative pedestal health can be shown. This is of considerable help to owners so they don’t have to play pedestal roulette after getting a bad one the first and/or second and/or third times. Saves calls to customer support as well.
  18. PLUS EV
    PLUS EV Running on Empty
    Seattle
    Can we please use black, white, yellow, blue or something? Roughly 5% of Tesla drivers are red/green colourblind :)
  19. cpa
    cpa Active Member
    Central Valley
    I think an easy fix would be to have a pop-up notice on the touchscreen appear when we are within a short distance (perhaps <2 miles) of a Supercharger.
    This pop-up notice would then indicate which of the available stalls to use. Tesla could also go so far as to steer us to the open stall that will accommodate our charging plans. If we want the fastest possible charge because we want to get back on the road, then perhaps it could direct us to 2A or 4B. If we are planning a one-hour stop over for dinner or shopping, then it could direct us to 1B or 3A--a shared stall with a lower initial charge rate.
    The red/grey lines with "4 of 10 stalls available" on the message do not correspond with the stalls actually in use. They are merely tick marks that are filled from left to right. Nice to have, but essentially useless when occupancy reaches and exceeds 50%.
