Well look at the SOC in the upper left corner of the image. The battery looks to be over 90% already...must have plugged in at 80% or 85%. Especially if this Supercharger is charging by the minute, this is not the way to Supercharge.
Try plugging in at 10% SOC and add 36 miles and I suspect you'll get a much better "deal".
The other comment I will make is that at a Supercharger you are paying for the convenience of being able to get that fast charge. It's not about the electricity you are buying. A lot of people like to compare the cost of Supercharging to what they get at home. Well, if charging at home is at a cost point that you like, then charge at home. If that's not practical because you need to charge at a remote location, then there you have it...that additional cost is giving you the convenience to be able to travel away from your home base.
Using that info in the image and assuming the display is showing 3miles/1kwh, that'd be 12kwh of charge. $3 divided by 12kwh is only $0.25/kwh, which I haven't seen since I was in Virginia or places west. Ever since getting to Maryland and further north it's gone up to as much as $0.30/kwh.
So who's the asshole?
Was not complaining or bashing anything. First time i ever supercharged this car. Was early to an appointment and across the street was a sc. Thought i would use this time to see what happened. Yes the battery wasn't that low, i didn't intentionally block that out. If that affects how much they charge for energy then there is anther item that could be improved. I was not aware that made any difference or why would it if you buy the electricity you need. No ill intentions was simply shocked at how much it cost for 36 miles of energy. No more than that
agreed. I just have a 14-50 but can go from almost empty to almost full overnight. I don't drive enough to require mid-day charging. The one place I do charge away from home is a chargpoint that is cheaper than the .175-195/kwh I pay at home.. . .
Multiple places here on TMC and other discussion forums around the web I've said that I would not own an electric vehicle if I couldn't charge it overnight where I regularly park it. Lots of people have disagreed with my statement, but honestly the biggest selling point for me with an EV is home charging both for operational cost reduction and actually making the car more convenient.
