Charging at a high rate also impacts the ability of the battery pack to retain it's original capacity over time. There is a battery engineering variable "C" that represents the capacity of the battery cell or battery pack. For the Model Y the current battery pack's total capacity is ~78kWh, the newer LG based battery pack that is now coming out has a capacity of 82kWh. When charging it is best for the battery to stay under 1 X C, or in the case of the Model Y under an ~80kW charging rate.With the free year of Supercharging, is it ok if I only use that to charge? I would only go up to 70-80%. Is that going to negatively affect the battery or do I need to mix in some home charging too?
It turns out that Urban Superchargers (SC) have a 72kW charging rate. The Urban SC are lower powered than the SC you find on the highway routes that offer 120kW, 150kW and the newest capable of 250kW charging. So if you want to make frequent use of a SC and don't mind that it will take a bit longer to charge then seek out an Urban SC whereas on a road trip the route planner tools such as ABetterRoutePlanner would have you skip the slower Urban SC in favor of one that charged faster. Even if you charge at a rate higher than 1C it will be fine but at their fastest the 3rd generation SC are capable of 250kW. That would be more than 3C for the short amount of time, in reality about 6 minutes, that the charging would potentially be at close to the maximum rate before starting to taper down.
