At maybe 12 months and 25k miles (lots of road trips) and maybe 7 AutoX events plus two track days, I started hearing the dreaded “ball joint rattle.” I have experienced failing ball joints before and was familiar with that low-load heavy rattling. Still, I went through every nut and bolt on the suspension a half dozen times, replaced the front top hats, added CR bearings, etc. I even tricked myself a couple times thinking I’d found the culprit only to realize I just hadn’t hit the right bumps in my test drives.
I ended up swapping in a new set of LCAs and CRs out of desperation to replace those ball joints, which finally told me one of those 4 ball joints was the culprit. However, these were cheap parts from Rock Auto, so the noise is starting to come back after about 10k miles or so.
I’d love to be able to drill maybe an 8-10mm pin hole on the backside of the joint to be able to push the ball joints back out with a punch, but I’m not sure if they are held in just by press-fitting, or via some interference method that would damage the arms upon removal.
