Tail Light Retrofit- AMBER turn signal
One thing I've always hated about my 3 was how they use the Brake light as the turn signal. I'm a big believer in a dedicated color(amber) for turn signal. Unfortunately a lot of manufactures are going away from that in favor for the brake/turn combo. Maybe it's cost savings.IDK, but I am out to change that.
I started looking into just purchasing the European model 3 Tail lights which have an amber turn signal factory(its required by law over seas to have a orange signal). The problem I ran into was the US spec cars are programmed to use the brake AS the turn signal. Which means than even if I got a European lamp, i would still need to find a way to change the computer system to flash a dedicated output for the turn signal.
So I purchased a set of stock tail lights and cut them apart. While inside I painted the chrome black which gave i a much cleaner look. Then I retrofitted a 3" Diode dynamics HD amber LED strip where the OEM reverse was. For the reverse, I retrofitted a 3" white LED strip right next to it(inner). The wiring was a bit tricky as I had to tap off the 3rd brake light for dedicated "BRAKE" then the front camera side markers for a dedicated "TURN" signal. Overall worked pretty well!
In the trunk, pass side there's a harness. Blue wire is 3rd brake light which is where I tapped off.
Running the turn wires through the trunk boot. fun stuff
here's a video showing the functions. They might look dim, but its out in direct sunlight. I assure you they are bright:)
Also you may notice they are hyperflashing because the car isn't seeing any load(i disconnected the stock brake/turn wire) I left them as is, but if it get annoying I will throw a resistor in there.
Also Decided to do blackout headlight, and AMBER DRL mod
Wait, so I can just look for OEM Y taillights and install them on my SR 3? Sorry for all the newb questions
Kinda of sorta ;). The Y taillights with the amber turn indicator do fit just fine on the M3.. I have 2022 lights on my 2019 M3. But, there are differences in the wiring on both the inner and outer. If you look at the connectors, the older lights were 3 pin plugs.. the new ones are four. You can easily make an adapter but then the amber lights go on with the brake lights. To get them to work properly, you need an adapter OR to hardwire them. The inners are also 3 pin to 4 pin but those a simple adapter OR just pull the pins from the 3 pin and install them into a new 4 pin plug which is what I did. The short cable adapter is recommended if you dont like messing with small delicate things like pins. The parts are easily ordered and it takes just a few mins to make up each one. The inners are NOT required but they are brighter than the older lights.. something like 18 watts vs 4 or so.. I forget the exact numbers. The outside light adapter is the real trick for clean job of it. Some made their own and one was being sold on Amazon. You can find who in the threads. I dont see them sold any more so you may need to ping directly and find out when or if they will make more. I've been very happy with my adapters and they took 15 mins to install.
Reactions: Hangerr
This sounds like a lot 😕
