Anyone contemplating an upgrade to the newest Model S tail lamp? Replacing the charge port door should be toughest and most expensive. Anyone know if the mounting points to the body are the same? Same wiring?
Modifying or replacing the rear strip should be easy. I assume the rear lights and right body side lamp swap is straight forward.
There is a remote chance that the wider body is a different shape in the rear. That could be a problem.
