Temperature control
Discussion in 'Model 3: User Interface' started by Nettley, Jun 14, 2018.
Tags:
  1. Nettley
    Nettley New Member
    West Vancouver, BC, Canada
    I have my 3 now and absolutely love it. One thing it like is a way to adjust cabin temperature more easily. Currently I'm tapping the up or down arrow on the screen. Which is fine but difficult to find while driving as it's small. A slider or voice command would be better. Anyone found an easier way?
    S
  2. Tdriver
    Tdriver Member
    Palm Desert, CA
    Nope, hoping for voice control soon. I would be nice to increase the size of all screen graphics.....clock, battery, energy bar, etc.
  3. Shygar
    Shygar Member
    Pleasant Hill, CA
    I don't think I have had a need to change mine after I set it to 70 degrees.
  4. SlicedBr3ad
    SlicedBr3ad Member
    Fl
    Same
  5. eadnjd
    eadnjd New Member
    Vashon WA
    My home thermostat has two settings, one for heat and one for AC. I would like my car to be just as convenient. One number would be OK if there was a way to set a dead band. If I could set it at 71 and have a +-3 degree dead band it would heat to 68 degrees or cool to 74 degrees if needed, and do nothing in between. This should not be hard to implement.
  6. SDKoala
    SDKoala Model 3 LR RWD
    San Diego
    I think we all are hoping for a better way to adjust the temp like voice or scroll wheel control. I'd settle for bigger screen icons as a first step. Way too much valuable screen real estate is being taken up by the front heated seat controls. They should give priority to controls that are used by 100% of people throughout the year, not just those who live in cold-climates part of the year.
  7. b.noing
    b.noing Member
    After 6 years of interface improvements the real estate is still formatted to a stationary car instead of one that is moving and bouncing. I can't understand why something so simple and easy has not been addressed.
  8. CapnOMatic
    CapnOMatic Member
    Gaithersburg, MD
    Same here too. I don't find the temp control hard to manage. I just put my fingers behind the screen to sort of grip it a little in case I bounce.
  9. DannyHamilton
    DannyHamilton Member
    Minooka
    I think you are perhaps all being far too careful when attempting to adjust the temperature?
    I find that if I get my finger pretty much anywhere on the temperature icon and then slide my finger up (to increase the set-temp), or down (to decrease the set-temp) then I get the adjustment I want.
    There doesn't seem to be any need to precisely tap on the little up or down arrows. A quick flick over the icon in the proper direction seems to work fine.
