I already took the bet when I moved the location of my panel in anticipation of what the inspector might say. In my case a delay was going to further delay my solar installation. I was looking at a $300 a month electric bill which I hoped to reduce significantly.
Don't overlook that the Powerwall+ must still switch to/from the grid, potentially under full loads at the meter, inside the 36" zone. It isn't all low voltage.Not sure if it matters, but the backup switch is powered via 12V from the gateway. Not sure if low voltage would get around that rule. My backup switch setup has worked out so far.
I read it as the PG&E site visit. In my case I submitted photos and delineated the distance.I read it as the former and it seems most are interpreting it as the latter.
Thanks. Sorry I am in SCE land and they don't do any onsite visit pre or post install.I read it as the PG&E site visit. In my case I submitted photos and delineated the distance.
It wasn't clear from the OP whether he is having the pre-install Tesla site inspection or the post install AHJ inspection. I read it as the former and it seems most are interpreting it as the latter.
If the rationale behind the NEC 36" rule is gas leak and electric arc ignition risk, Tesla would (ought?) to demonstrate something akin to explosion proof operation. Personally, I don't see the upside to Tesla in doing that.
From my couch, it looks like a win-win bet for @Eric99- if the inspector passes it, he is good to go today. If the inspector fails it, he gets a system that more closely aligns with existing codes, and potentially even safer. So, no, @holeydonut I don't think I would take either side of the bet as it looks like a "heads @Eric99 wins, tails I lose bet..."
Have fun out there!
BG
well, im hoping that if the backup switch isnt an option, they can just go with a gateway
Yes it seems to be unique to PG&E because they provided both services and allowed both meters to be closer together at one time. I used to live in SCE territory and I never saw SoCal Gas and SCE install equipment close to each other.I am in SCE land and they don't do any onsite visit pre or post install.
Panel is opposite on the left side. That is a gas line as well
In that case, bring it up to the Tesla rep doing the inspection. That will get Tesla on record in saying OK or not. If it was like our Solarroof inspection it should be pretty thorough. The guy went everywhere in our house outside, attic, etc. And opened every electrical panel and box and checked the wiring.Sorry! its the site visit from Tesla. Im just starting the process of Roof/Powerwalls.
