Tesla’s first building phase nearly complete | Las Vegas Review-Journal
The FastCompany article linked a few posts ago just confirmed this 14% number.
What is being built today and then equipped by Panasonic etc. until 2017 (when EV cell production starts) is just a fraction of the total GF.
So the "completed" 14% is not the entire structure that you see, it is a small part of that. Why do I know this? Because even the latest photos of the site shows open steel frames on the far side of the building. Sure they have raised a wall around the outside coming across the full length of the building, but the backside is still not covered. You can't very well be certified to move into a structure that doesn't even have walls all the way around it. This means that the 14% is less than the size of the structure you currently see. It may even only be that first "block" of the building out of the 4 "blocks" we saw as the structure went up (with the fifth having been pulled down, for whatever reason). If you remember when Elon's brother posted photos from the roof of the building they stated that the current structure was something like 25% of the completed building. So you have most likely around half of the visible structure having been "certified" for use.
Given that we also know that the building plans are for 5 phases of construction (assuming they are still sticking with those timelines) it was suspected that phase 1 was the largest piece of the factory. What we might have actually seen happen is that phase 1 kept going in the middle of starting phase 2 (phase 2 likely started by raising more steel than needed for that first 14% of the factory).
This would imply that they are actually in the middle of Phase 2 of construction and possibly also starting Phase 3 in parallel. Again, the original timelines that were published showed this overlapping period between the phases.
Point is, you are cherry picking the data to meet your narrative, which I still don't even understand what is so negative about what you are suggesting overall anyway... but in either case, I don't think 14% is what you think it is.
Combine that with comments that they were planning to go bigger than originally stated (they added a whole extra floor on top, it was originally to only be a 2 floor building) and that they have already underestimated how much production they would get out of the usable space by doing a more optimized flow, and you don't have any accurate way of attributing the amount of money already spent vs what they still need to spend.
So to your points:
- Tesla spent most of the funds raised in early 2014 on other items (not on the Gigafactory), all that cash is spent as of late 2015.
I already rebuffed this, it depends on how you look at their spending vs capital raises. Do you deny that they are sitting on 1.4B in cash? at the end of 2014 they had 1.9B, at the end of 2013 they had 845M, and 2012 201M. I said this previously, and I'll say it again. They are still sitting on enough cash currently to finish building out the factory (at least their share of it), Every time it depletes down from other spending they pull it back up again with some kind of cash flow injection (e.g. line of credit, capital raise, etc). The only thing any of those other cash flow injections after the major one happened has not been stated for is to add on to the gigafactory. All of the cash additions have been to ensure they keep enough cash on hand to continue to expand the gigafactory at a pace that works for them, while being able to grow other parts. So no, they "technically" haven't spent all the gigafactory money, because there is still 1.4B sitting as cash on hand.
To put it another way, it isn't like when you do your own personal finances that you go and physically separate out your cash. 1k for housing, 500 for car, 250 for food, 250 for other stuff... right as your paycheck comes in, you immediately separate out that cash, even though you might be getting a whole other paycheck (assuming bi-weekly paychecks) before you owe on your house. As long as you pay for your house when it is due, it doesn't matter if you pull 1k per paycheck or 2k in one paycheck does it? And if your grandma gives you 100$ and says, here I want you to buy 100$ in clothes (gigafactory raise), you turn around and spend that physical 100$ immediately on a fancy dinner with your significant other (building out fremont), but then take 100$ from other cash flows coming in like your paycheck (Tesla doing the 750M cash raise) to buy those clothes your grandma wanted, did you not still end up spending 100$ like you promised? Does it really matter that you didn't spend that specific 100$ she gave you, physically walk over to the store with that 100$ bill that she wrote on the front of it even "from grandma with love", and set it on the counter to pay for clothing??? No, it doesn't. In the end, you still spent 100$ on clothing.
Now, stop playing semantics over their cash...
- Tesla is only building out 14% of the entire GF building structure at the moment (late 2015).
See my comments above, there is no way that 14% is the full entirety of the visible structure. the visible structure is very likely greater than 25% of the total building
- Tesla can equip a much smaller number of Model3 cars/year unless it adds the remaining buildings. It wil again take 2-3 years to ramp up production from the moment new construction starts.
Cool, they are already doing that. The point at which they stated to hit 500k a year was by 2020, as long as the building is completed by 2017 as their original timelines stated it would, then they have 3 whole years to move in equipment and get things up to 500k. What we know is they are on track to start cell production well ahead of needing it for the Model 3, and their construction timeline leaves them with 3 years to fully ramp production. They didn't specify that in 2017 they would make 100k, 200k, or whatever arbitrary number of cars. They said they would *start* production in 2017 of the Model 3, and be doing 500k in 2020. I see nothing that says that they won't be able to do either of those stated goals. The specifics behind getting from 1 car to 500k hasn't been outlined yet, or even hinted at... so I am not sure what your point is here.
- Tesla will have to raise substantial additional funds for the completion of the GF and the Model3 (unless you believe it can cover this with positive cash-flow, if so please add your numbers or estimates how this is possible in 2016+. I don't think this is remotely possible even when assuming much slower cash-burn going forward).
People have provided plenty of ways that the factory can self-fund the rest of the expansion should they decide to go that route, in this thread and in many other threads... if I recall the only rebuff was "they won't hit those margins necessary to do that", but noone ever provided a proper counter reasoning why they couldn't hit the margins... So quid pro quo, why don't *YOU* provide numbers and data as to why this isn't possible using numbers that others have been so kind to provide in the past on estimated sales, gross margins, operating costs, and assumed net profits (minus cost of expansion, cap ex, and increased spending as they grow out the sales, service, supercharging, and other things). Convenient to say "I don't think it's possible" while pushing the burden of proof off on someone who actually has responded to provide this information in the past. The best one I ever saw posted on this was by DaveT, go back and read through his thread as to how they could use the funding from one factory to enable exponential growths assuming they can maintain a remote semblance of margins of what they are doing now.
