I've heard a lot of conflicting information about the size of the Gigafactory. We heard a lot of detailed information regarding the size of the Gigafactory from Dean Haymore, Story County commissioner, in
this video (skip to 2:25), posted back on July 13, 2015. Now, there's a
new article out today from journalist, Max Chafkin, who visited the Gigafactory, which provides more conflicting information. Here are the facts from each of the two sources + Google Earth:
Dean Haymore (7/13/15):
Current building (Block 1) square footage: 2,500,000
Total square footage of building once complete in 2020: 24,000,000. Note: he uses the term 'structure' when referring to area, implying that this includes all square footage, including areas that are typically left out of square footage specs, such as kitchens, bathrooms, utility rooms, etc. He may also be including the surface of the roof which I will get to later in this post.
Floors: First floor will be at 0', mezzanine level at 23.5', third floor at 41', and roof at 71'. Note: 'mezzanine' seems to imply that the second floor will not be continuous, but may only exist in certain areas of the factory.
Blocks: There will be a total of 7 blocks (presumably of roughly equal size) that will be constructed to form the final building. The current structure is Block 1.
Max Chafkin (11/17/15):
Current building (Block 1) square footage: 1,900,000. Note: he uses the term 'factory space'. Therefore, this may exclude non-factory space, such as utility rooms, kitchens, bathrooms, etc.
Total square footage of building once complete in 2020: 13,600,000
Google Earth:
Using the measurement tools in Google Earth Pro, I have found the current building (Block 1) to have an 800,000 sq ft footprint as seen below:
Okay, so looking at these facts, there are some obvious contradictions regarding the size of the factory. Firstly, Chafkin claims that the current building (Block 1) is 1.9 M sq ft, whereas Haymore says 2.5 M sq ft. My theory is that the difference between these two numbers is what is meant by 'square footage'. Haymore uses the word 'structure' to describe area, whereas Chafkin uses the word 'factory space'. I believe Chafkin's 1.9 M sq ft is referring to the actual usable factory space, whereas Haymore's 2.5 M sq ft refers to the entire sturcture, including kitchens, bathrooms, utility rooms, etc. Assuming this is true, Block 1 will consist of 76% 'factory space' (1.9 M sq ft / 2.5 M sq ft). This brings us to our second contradiction...
Haymore claims that Gigafactory will have a total area of 24 M sq ft ('structure') once complete in 2020, whereas Chafkin claims it will have a total area of 13.6 M sq ft ('factory space'). If we assume the completed Gigafactory will have 76% factory space, using Haymore's 24 M sq ft of stucture, there should be 18.2 M sq ft of factory space, not 13.6 M sq ft. So what happened to the other 4.6 M sq ft??? To find out, let's take a step back. Haymore claims that the Block 1 stucture is 2.5 M sq ft and that there will be 7 blocks. Using photoshop, I have overlaid an area equal to 7 times that of Block 1 over the sattellite image of the Gigafactory, and it lines up perfectly with the bounds of the construction site as well as Telsa's rendering, implying that, indeed, the final factory will by seven times the size of block 1. See my photoshopped overlay below (Block 1 outlined in red) compared to Tesla's final rendering of the factory:
So, if we assume that the Gigafactory will be 7 times the size of Block 1, then the Gigafactory should be 17.5 M sq ft of structure (2.5 M sq ft x 7), not 24 M sq ft as stated by Haymore. So why the discrepency? First, let's look at the footprint of the factory. From Google Earth, we know that the footprint of Block 1 is 800,000 sq ft, which implys that the finaly factory will have a footprint of 5.6 M sq ft once complete (800,000 sq ft x 7). By the way, this would make the GF the largest building in the world by footprint, which no one seems to be talking about. So, if the footprint is 5.6 M sq ft and the total structure is 24 M sq ft, then there would have to be an average of 4.3 floors. One might say, "but there are only 3 floors!" However, looking at recent construction photos, I have noted in previous posts that it appears that Tesla is adding a 4th floor. See image from my earlier post below:
But 4 floors is still less than 4.3 floors, so what's the deal? It could be that the final factory will actually be slightly larger than 7 times it current size, giving it a footprint of 6 M sq ft, rather than 5.6 M sq ft. If that were the case, 4 floors would make it exactly 24 M sq ft. However, again, this contradicts Chafkin's claim of 13.6 M sq ft (17.9 M sq ft of structure if you assume he is implying 76% 'factory space').
So, there could be a few reasons for the discrepency:
1. Both Chafkin and Haymore are right, but their facts have been misinterpreted. It could be that Haymore's claim of 24 M sq ft includes the roof of the building (note: his claim of 2.5 M sq ft for Block 1 seems to exclude the roof, since 2.5 M sq ft x 7 blocks = 17.5 M sq ft, not 24 M sq ft). If this were the case, the actual structural area of the building (excluding roof) would be 18.4 M sq ft (24,000,000 sq ft - 800,000 sq ft * 7 blocks) or 2.63 M sq ft per block. This 18.4 M sq ft is very close to Chafkin's implied 17.9 M sq ft, so this is an extremely plausible explaination. Also, note: Haymore's claim of 2.5 M sq ft could reasonably be considered an approximation of 2.63 M sq ft per block, which would explain the discrepency of his implied 17.5 M sq ft (2.5 M sq ft x 7 blocks) of floorspace vs. 18.4 M sq ft (2.63 M sq ft x 7 blocks) of floorspace.
2. Both Chafkin and Haymore are right, but their facts have been misinterpreted. The final factory could have a much lower 'factory space' utilization of 57% (13.6 M sq ft / 24 M sq ft). I can't imagine 43% of the factory being used for something other than factory space, so this would be an extremely unlikely explaination.
3. Chafkin is wrong and Haymore's claim of a 24 M sq ft structure actually implies that there will be future floors added and that there may be areas with as many as 5 floors. I don't think that this is likely since adding a 5th floor would start to make things pretty tight. The maximum height of a 5th floor would be about 10' if they split the bottom level in two.
4. Chafkin is wrong and Haymore's claim of 24 M sq ft actually does refer to floor space, implying that the factory will be much larger than anyone else is claiming. For this to be true, however, there would need to be an average of 4.3 floors as previously stated. This does not seem likely.
5. Haymore is wrong, and the factory really will be 13.6 M sq ft of factory space (17.9 M sq ft of structure if you assume Chafkin is implying to 76% 'factory space').
6. Haymore is wrong, and Chafkin's claim of 13.6 M sq ft actually does refer to total floor space. For this to be true, however, there would need to be an average of 2.4 floors (Chafkin's claimed 1,900,000 sq ft area of block 1 / 800,000 sq ft footprint of block 1). This seems unlikely, given that you can already clearly see 4 floors (at least in some areas) from the construction photos.
In summary, I think that option 1 is the correct explaination (however, I would like to believe option 4 to be true). I think Haymore's comment about 24 M sq ft includes the surface of the roof of the GF. Therefore, I believe that the final GF will have 18.4 M sq ft of floor space (13.6 M sq ft of which will be dedicated factory space), have a footprint of 5.6 M sq ft (making it the largest building in the world by footprint), and have an average of 3.3 floors (meaning that there will be 3 floors in most areas, maybe 2 floors in some areas, and 4 floors in other areas).
So, what do you guys think? How big will the Gigafactory be, given all the facts out there?
