Can you explain that? How is FWD better for acceleration traction than RWD?
I have driven both rear and front wheel drive cars and the only difference I have observed is the annoying tendency to torque steer in FWD and better ability to accelerate out of a skid with FWD.
It's true, and fairly easy to explain. Note, though, that there's no difference until the front wheels lose traction and start to spin, which will happen at a lower acceleration than in a RWD car.
Every car has a center of mass, which (viewed from the side) will be roughly in the middle, between the front and back wheels. In the case of a stationary car (or one moving at constant speed), the weight on each pair of wheels depends inversely on the distance of those wheels to the center of gravity. So in a car with the engine in front above the wheels and pretending that the rest of the car weighs nothing at all, all the weight will be on the front wheels and none on the back wheels. In reality, of course, there will be some amount of weight on the front and some possibly different amount of weight on the back wheels. Many serious sports cars have the engine in the middle or slightly behind (Ferrari etc.) to try to get this weight balance to be as close to even as possible, for good handling.
Aside: an interesting demonstration of this is to take a flat stiff object, like a ruler, and lay it over your index fingers at each end. Then start moving your hands together. Initially one finger will start to slip, but as it approaches the center of the ruler, more of the weight of the ruler will be supported by that finger. Eventually the friction between the ruler and that finger will increase to the point that that finger will grip, and the other finger will start to slip! It doesn't matter how you do it, until your fingers get quite close together, the ruler will stay roughly centered between them, and will self-correct to make sure this is true.
The center of gravity of the car is also above the road, not at street level. Now, acceleration comes into the picture. Acceleration and gravity are physically interchangeable. Initially you had a gravity force pointing straight down, but now you're accelerating so you have a corresponding gravity-like force also pointing towards the rear of the car. The resulting net force is angled down and back, and the more you accelerate the more angled toward the rear it gets. Where that angled force line meets the road, that's the
effective center of gravity of the accelerating vehicle. So the weight on the front wheels decreases (as does their grip from friction) while the weight on the rear wheels increases (as does their grip). If you accelerate enough that that point moves behind the rear axle, you pop a wheelie, like drag racers or motorcycle riders can do.
