SwedishSTIle
Haldex is garbage. They are FWD biased with unnecessary turns the system due to a transverse engine layout. They would not do as well in this test since barely any torque goes to the rear. MB uses three open differentials and cannot lock (fail), and BMW X Drive uses a chain to turn a forward shaft (fail). The only systems worth buying are Subaru manual transmissions (Viscous-Coupling Continuous and STI DCCD), and Audi longitudinal (TorSen center...not TT or A3, which is Haldex). Subaru Active (CVT/AT) system is the best clutch-based center system, because it always sends power back 60/40 and has a longitudinal engine layout (Symmetrical). A 4x4 would need to slow down, lock the center differential, and then disengage above 30 mph. The benefit of Subaru DCCD is the ability to have 3 mechanical differentials, including the driver controlled center, which can fluctuate the amount of lock as 59:41 to 50:50, to allow enough slip for high speeds. I'd rather that than needing to lose traction with a RWD based 4x4 until I slowed down to a crawl..
Ok, before We go back and forth here, I have actually owned and driven all of these systems in the real world, my understanging of them is both technical (im a mechanical engineer), theoretical, and empirical:
2008 Subaru WRX STi Hatch
2015 Audi Q5
2014 Bmw X3
2016 GLC 300 4Matic
2015 Ford F-150 4x4 with electronic locking rear and TrueTrac front on 34's
2018 Volkswagen Atlas 4Motion (current)
2016 Mercedes Sprinter 4X4 (current)
Haldex systems are are efficient and exceptionally capable. I guess you dont own any cars with a Haldex in it. Most clutch based systems are very tuneable and very good on slick surfaces. Every driven a car with a clutch based limited slip rear? They are awesome.
A quick search and the Tiguan seems to do pretty good.
I have a 4x4 Sprinter with selectable 4matic as well as an Atlas 4Motion. My last large vehicle was a 15 F-150 4X4 with electronic locking rear and a TrueTrac front. I could shift on the fly into 4X4 at any speed (didnt need to slow down) and the TrueTrac is always active (electronic locking rear drops out above 20mph). In snowy/icy conditions the Atlas is one of the the best vehicles I have owned, and my sprinter is completely unstoppable as was my truck.
Is haldex complicated? Yes. Is it also a very good system? Yes.
I didnt dig her out, I drove her out, and then flattened the parking lot for my neighbors with her.
I know a thing or two about 4wd and AWD vehicles and systems, as well as driving them.
On the other hand my Subaru STI with a 6speed, DCCD center could easily stick two tires on one side and spin the other side indefinitely, overwhelming even the DCCD set to full "lock:". And thats with Blizzak tires in mixed snow and ice.
I wanted to believe when I owned the Subie that it was the best winter vehicle. When it comes to control at high speeds in adverse conditions, I would not trade it for anything. But for getting out of deep snow, getting unstuck from freeze/thaw conditions, and other situations simulated by rollers, it just wasnt that capable in comparison to more dedicated 4X4's.
Your knowledge of classic 4x4's seems to be about 20 years old. Modern 4x4 trucks have 4A which is shiftable on the fly, and is code for 4 automatic, and it will engage the front drive shaft as needed on the fly for mixed dry/snowy conditions. 4x4 is also shiftable on the fly at ANY speed these days. Gone are the days of getting out and locking your hubs, or shifting to neutral to engage 4x4.
