Front Seats, gray color, great condition $500 (from 2013 Model S) Next Gen Rear Heated Seats, full set, gray color, great condition $1000 (from 2016 Model S) Rear 2nd Row seat frame $200 (from 2016 Model S) 1032224-00-A SRS Safety Restraint Airbag Control Module $200 (No Crash Data) 1005273-00-F SRS Safety Restraint Airbag Control Module $200 (No Crash Data) Brand New Carbon Fiber Dash and Console Trim set, 4 pcs, $1000 (fits Model S and X) 1010906-00-C Body Control Module with key fob $350 1010906-00-D Body Control Module with key fob $350 BJ32-3200-HB 2012-2015 Power Steering Rack & Pinion Assembly $350 6009278--00-F 10kW On Board charger module Gen 1 $350 6006351-00-C Front Left or Right Air Spring Shock Strut $250 6006352-00-C Rear Left Driver Side Air Sprint Shock Strut $250 1097814-00-A 2017-2018 HomeLink Control Unit Garage Opener $250 6006403-00-A Air Suspension Compressor Assembly $250 1012209-00-B High Voltage HV Main Battery BMS Board $250 (from 2012 Model S) 1004422-00-E Front Instrument Panel Dash Wiring Harness $250 (from 2012 Model S) 1004423-00-E Front Body Wiring Harness with Fuse Boxes $250 1005312-00-E Front Right Body Wiring Harness $200 1004417-00-E Front Right Body Wiring Harness $200 1004416-00-E Front Left Body Wiring Harness $200 Signature Edition Left and Right Side Markers Turn Signals $200 1057356-00-A Column Cover, Switches, Heated Steering wheel option $200 6008047-00-E Battery Coolant System Pump $200 (from 2016 Model S) 6006359-00-A ABS Brake Vacuum Pump with bracket $200 1004556-00-D Top Roof Headliner Light Wiring Harness $150 6007092-00-A Rear Sway Stabilizer Anti Roll Bar $150 6007084-00-D Front Sway Stabilizer Anti Roll Bar $120 1043961-00-B Rear Sway Stabilizer Anti Roll Bar $150 6008118-00-A RWD Brake Power Master Cylinder with Booster $150 Front Right Passenger Side Door Window Glass $150 Self Leveling Air Suspension Compressor Pump Valve $150 6007373-00-E Battery Coolant System Pump $125 Panoramic Roof Upper Trim Bow Cover Panel Zuma Alcantara $100 6007572-00-C Front Secondary Lock Latch Assembly $100 1027643-00-A Rear Left Driver Side Brake Caliper with hose $100 1013272-00-E 12V Battery Fuse Box $75 1004293-00-D 6008481-00-A AC Line with TXV valve $100 Chrome Rear Trunk Latch Trim Cover Panel $100 1030182-10-E Junction Box to Charger Port Rear High Voltage Cable $100 1004557-00-E Front End Module Wiring Harness $100 1007512--00-B Sunroof Control Unit Module $100 6005946-00-B Front Windshield Wiper Motor Regulator $100 Right Passenger Side Sun Visor Zuma Alcantara $100 6010351-00-D HV Battery Coolant Tube Break Assembly $100 Dual Motor AWD 12V Battery Tray Holder Support Bracket $100 1033010-00-A Hood Frunk Lock Latch Actuator with Secondary Cable $100 1004425-00-P Rear Left Side Door Wiring Harness $90 1004425-00-E Rear Left Side Door Wiring Harness $90 1004426-00-E Rear Right Side Door Wiring Harness $90 1004424-00-P Front Right Passenger Side Door Wiring Harness $90 6006413-00-B Air Suspension Control Module $90 1013535-00-B AC HVAC Filter Housing Boot $80 Liftgate Trunk Left and Right sensors 1007511-00-A Power Liftgate Control Module $50 1007512-00-A Sunroof Control Module $50 1014388 NEW Parking Assist Sensor with rubber cover $30 each Ride Height Level Sensors All Four door actuator mechanism, driver, passenger, rear left and right All Four door handles, front driver, front passenger, rear left, rear right (from 2012 Model S)
What exactly is this? Got any pictures or link to share? "Signature Edition Left and Right Side Markers Turn Signals $200"
Interested in the parking sensors. What color are they currently? Also do you have the front or rear bumper harnesses for them?
Thanks. i ended up ordering them online last night for $8 each on ebay. The clear rubber rings were only $4 from Tesla. Had no idea they were so cheap. GLWS
Hard to tell from the item list but do you have the full headliner and A,B & C Pillars in Black Alcantra? If so can you post any pictures and the price for the full set?
