@trykkertor Yes it does. I installed over the weekend on my 2021 Model Y.Did the version 5 come with the emergency pull rope that routes down to the tow hook hole?
@trykkertor Hmm ... that doesn't seem to be the latest version then. The emergency pull cord should be included. I wonder if they forgot to pack it? You know, these things could happen. Can you request them to send the emergency pull cord to you then since it's missing and they confirmed it's V5 as well?Thank you for your response. Just got the version 4.4 today, and it does not have the emergency pull cord.
Asked the seller if they sold version 5. "Yes, yes. Latest version. Version 5".
In the mail the cardboard box says version 4.4, the control box, says 4.4, and the kit does not have the mentioned cord.
Hi, I'm new here...Thank you for your response. Just got the version 4.4 today, and it does not have the emergency pull cord.
I had this installed in my Model Y and it will not latch...stops before it hits the latch. Have contacted Hansshow and they offered a software update.. still doesnt work! Suggestions?Just installed Hansshow Power Frunk Version 5.0
was worried about the hard it was going to be to install, but it turned out to be not so bad!
Make sure to take your time when attempting the installation, easier than you think!
I had the same issue when installing mine, I had to disconnect the power for the motor that some with the Hansshow kit and let it release the cable a little manually. What was happening is that the cable was pulled to tight on that motor they send out and it needs to freespin a little to loosen up. It worked like a charm once I did that. You might also have to lock and unlock the mechanism a few times to get it to where it needs to be.I had this installed in my Model Y and it will not latch...stops before it hits the latch. Have contacted Hansshow and they offered a software update.. still doesnt work! Suggestions?
Hi Solelo,I had the same issue when installing mine, I had to disconnect the power for the motor that some with the Hansshow kit and let it release the cable a little manually. What was happening is that the cable was pulled to tight on that motor they send out and it needs to freespin a little to loosen up. It worked like a charm once I did that. You might also have to lock and unlock the mechanism a few times to get it to where it needs to be.
