Getting rid of the 12v low voltage architecture and moving to 48v. Tesla Confirms The Switch To 48 Volt System
It is likely they will incorporate signaling into a new 48V architecture (meaning one wire for both power and control), as well as a distributed module bus so that all wires don’t have to go back to a single point.Is there a benefit other than thinner wires?
Generally easier power management & distribution. Smaller fuses, lighter and more flexible wiring, simpler components...Is there a benefit other than thinner wires?
85% of Cybertruck modules are made by Tesla. 100% of Gen 3 will be.It's a complicated, bold move however it does allow for smaller gauge wiring. Accessory makers are going to have fun trying to adapt however it is doable at a higher expense though. Oddly enough, Starlink works off of 48vdc also.
It all started with 6v systems, then the move to 12. Big rigs and larger boats operate off of 24v. I know our electric forklifts operate off of 48v. 48v is supposed to be the future of solar as it is more efficient to run a system at this voltage. Everything EV today is based on efficiency.
I also expect 12v sockets and usb ports to retain their voltage however aftermarket puddle lights and the struts for an auto frunk would need to be 48V. Want to change the led bulb in the trunk? You will need 48v versions. I doubt they will run another entire sub structure on 12v. They will need to continue with some 12v stuff such as hooking up trailer lights on a Y, we just do not know how far they will take the 48V system.By accessory makers, do you mean 3rd party historically 12V stuff? I'd expect Tesla to add standard voltage port(s). Or USB-C converters.
P=V*AIs there a benefit other than thinner wires?
It's not difficult to run a string of LEDs off 48V.I also expect 12v sockets and usb ports to retain their voltage however aftermarket puddle lights and the struts for an auto frunk would need to be 48V. Want to change the led bulb in the trunk? You will need 48v versions. I doubt they will run another entire sub structure on 12v. They will need to continue with some 12v stuff such as hooking up trailer lights on a Y, we just do not know how far they will take the 48V system.
