Yeah, it's worse than a Pontiac Aztec.
$100 is not a commitment.Yeah, it's so bad there are 1.5M reservations
Or a Cybertruck pulling a gooseneck/fifth wheel trailer with a Rivian And a Lightning on board.How about a Cybertruck towing a Cybertruck on a Trailer. It would give us an idea about the Truck's towing capacity.
5th wheel issues with the CT.Or a Cybertruck pulling a gooseneck/fifth wheel trailer with a Rivian And a Lightning on board.
That could work depending on how sharp of a turn you take.Ooops, Hadn't thought of sleeper style square front trailers. Maybe a utility trailer would still work with the V style front. We were a bit over weight on the RAMs gooseneck trailer.
I guess it will be bumper pull for the Cybertruck those rear sail panels will likely be at risk backing a trailer anywhere near 90 degrees.
After thinking a bit, having doubts.... the trailer also needs clearance for when the truck goes up a sharp incline and then levels off or starts back down. The side of bed clearance can disappear quickly.That could work depending on how sharp of a turn you take.
I just think it's ugly.
I think they are actually in production and also have two companies that have ordered 100 trucks each. The IRA may help out a lot with this situation from my reading.Meanwhile, construction continues at the Nikola factory site
I did at first as it was too angular but it grew on me. If it is still ugly to you now my guess is it will always look ugly to you. It has been described as a polarizing design.
You're arguing whether rectangles are better looking than triangles.
