Okay guys. I've set my charge limit to 80%. Since I have a wall connector in the garage and can charge at will, it won't be a problem and might extend the battery a little bit down the line.
This charge limit will not extend the battery. If that's your goal, here is the simple answer.
1) Set your charge limit to 55%. This will minimize battery degradation over time based on the best science and research available. This is still enough charge to cover four of your daily commutes so way more than you need daily.(In case you were to ever forget to plug in or something).
2) Plug in every day when you come home and use scheduled departure. This will keep your car at a slightly lower state of charge until you are ready to drive, which helps minimize degradation slightly more. This also warms the battery a little bit right before driving "for free" i.e. you aren't using extra electricity to precondition.
If keeping your battery in the best condition possible with the least range loss over time without any effort i.e. set it and forget it, matters to you, this is how. If that doesn't matter, just do what you want. Many, as seen in this thread, do just that. I.e. "I just set mine to 90% and charge every night." (for basically no important reason), and they are happy with degrading their battery more than necessary.
For me personally, I find a set it and forget it solution that always gives me far more range than I need while optimally minimizing battery degradation is the right solution. No downside, lots of upside. I paid extra to get the most range possible from an EV.....I'm not going to degrade it on purpose for no reason.
In the unlikely event that you ever need to do an unexpected long road trip and don't have time to top off at home, just stop at a nearby supercharger for ten minutes. Or drive a couple hours then stop. No reason to keep the car at 90% daily, IMO. I never filled up my car every single day when I drove a gas car. With Tesla, this is no different.
Another thing that you are doing to optimize your battery that is not optimal...charging to 75% and dropping to 30% before charging. Small, frequent charges are better than large infrequent. So again, points 1 and 2 above is the simple and science based method to optimally minimize battery degradation.
See post 18:
I have a 2021 Shanghai-built M3P with the 82 kWh Panasonic battery. My understanding is that the following four charging regimes all take the same amount of power: Daily charge - 60% to 80% Daily charge - 40% to 60% Every other day charge - 40% to 80% Every other day charge - 20% to 60%...
teslamotorsclub.com
