The Scheduled Charging and Scheduled Departure Charging are location based. That may explain why Scheduled Departure Charging is behaving differently, i.e. charging immediately for one user versus completing charging by 0630 for another user.
I will give it a try on a weekday next. I also will try it later in the day as I wondered if my test at ~11AM caused it to want to charge right away as it was a long time till the set 7:45AM the next day.I'm not sure why it works this way for me and not for you, but I suggest you try it again on a weekday vs weekend. I've been playing around with all the settings and I had set up everything, including utility rates, off peak settings, etc. Off peak was all set for 3 PM weekdays then I turned it off. Went with only scheduled departure at 6:30 AM and it didn't start charging till the wee hours of the morning all week. However, when I plugged it in yesterday (Friday) evening, it began charging immediately and I could only assume because the next time 6:30 AM was rolling around, it would be Sat morning and not a weekday. So somehow it seems taking the days of the week into consideration even though that's an off peak setting. Question, @ what amperage are you charging? I've got the latest Level 2 Wall Charger set at 48A and was only recharging 15 to 20% back to set limit. Just trying to hash out any differences we might have.
PS: I didn't see anything in the manual saying "If you don't use Off-Peak it doesn't delay charging."
Yes, scheduled charging is off. Lemme ask, is it truly charging to completion as soon as you plug up? Can't quite recall but I think mine flash for a minute like it would start to charge, then shut down the charging, either that, or it went blue. On the app, it would have a message something like "ready to depart at 6:30".... I'll try to grab a screen shot on Monday.I will give it a try on a weekday next. I also will try it later in the day as I wondered if my test at ~11AM caused it to want to charge right away as it was a long time till the set 7:45AM the next day.
I'm on Tesla WC off of a 50A breaker so set to charge at 40A. My test yesterday was 30-50%. But my normal weekday charging is only adding 4% each day. Usually I have that set at 65%, plug in around 5:30PM. I'll try that on Monday evening. My Scheduled departure and Off peak are set for all 7 days of the week though. I just sometimes mess around with the % and times on the weekends.
Can I just double check that you aren't using Scheduled Charging setting? You have that to Off? Only reason is you mentioned that weekdays vs all week is an Off-Peak setting but it is both a Scheduled Departure and an Off-Peak setting. Only Scheduled Charging doesn't have that option. Scheduled Charging and Scheduled Departure don't work together AFAIK. My Scheduled Charging (2nd tab on the app's charging settings) is turned off as all my schedule is controlled by scheduled departure and off-peak.
I haven't left it to charge to check if it keeps going. With Off-Peak turned off, I plugged in, it went green, the car screen said charging and said 2hr something to compete charging. Only left it like that for 30s or so. When Off-Peak is turned on, I plug in, flashes green for 1-2s and then back to blue.Yes, scheduled charging is off. Lemme ask, is it truly charging to completion as soon as you plug up? Can't quite recall but I think mine flash for a minute like it would start to charge, then shut down the charging, either that, or it went blue. On the app, it would have a message something like "ready to depart at 6:30".... I'll try to grab a screen shot on Monday.
If keeping your battery in the best condition possible with the least range loss over time without any effort i.e. set it and forget it, matters to you, this is how. If that doesn't matter, just do what you want. Many, as seen in this thread, do just that. I.e. "I just set mine to 90% and charge every night." (for basically no important reason), and they are happy with degrading their battery more than necessary.
Set it and forget it. Or just do what you want. I tend to err on the side of whatever the company recommends. But TETO.
That's all totally normal. Don't worry about anything, everything you're doing is fine.I settled on charging to 75%. Plugging in daily and charging to depart by early morning Occasionally I charge to 90% if relatives are in town or im doing long runs.
My battery percentage never drops below 50% and I don't know if that's a bad thing because lately my scheduled charging overshoots the set percentage by a few points. If I set to 75, it charges to 77%. If set to 90, it charges to 92, etc. Anyone experiencing this? Im thinking I need to stop being anal and let it drop to about 10% now and then.
Thanks for the reassurance. I hope that one day Tesla pushes out a software update that can prevent the calibration from drifting, or provide tools that can easily get it back in alignment. I've heard of something in the service menu that can do this but also that it's difficult to use and can be dangerous to the battery if used improperly.That's all totally normal. Don't worry about anything, everything you're doing is fine.
If you take a longer trip maybe 6 times a year, and it gets down around 10-20% SOC, and sleeps at night, your SOC estimate will stay calibrated (or something like that).
If you never do that, it still won't hurt anything. Just know your SOC prediction might be a bit off, and add a bit of buffer on the first few legs of a longer trip, just to be safe (ie, charge 5-10% more than the car thinks you need).
I charge a lot like you do, 50-55 or 45-75% most days.
On long trips every 6-8 weeks, the first 2 legs are usually a bit off on the arrival SOC, up or down by as much as 10%.
Somewhere around the 3rd or 4th leg, it starts predicting within 2-3%.
Through all of this, your battery is fine, nothing is actually changing in the actual capacity of the battery. The computer calibration just drifts a bit.
We like to think that a Tesla vehicle can last for beyond 15 years. In reality most Tesla vehicle will be sold or traded long before the battery needs to be replaced.
There are many possible points of failure in the battery pack. Corrosion, bad cells, broken welds, faulty temperature sensors, pyro fuses. These can and do sometimes fail and brick a battery pack.They can last 15 years if the pack is not abused. That the car may have more than one owner is a different matter.
Since you brought up humans, I would not bet against the actuarial tables to plan on living to 100+ years. The odds are against it happening.There are many points of failure in a human. That is no reason to get fat, smoke, or walk across streets with your eyes closed.
Although my utility TOU rate doesnt have off peak rates till June thru Sept, I decided to get used to charging at the off peak time. It completes charging about 20 min before I leave and spends most sitting time in the high or low 60s percentage before being charged again.In practice this works out to plugging in about daily, and changing *when* the car charges in the summer Vs winter. We are retired and share one car. Charging up to ~ 70% works well for us. For trips I top off in the morning before we leave.
According to this study, keeping the charge between 65%-75% is ideal. But 45% to 75% is more practical. 30% roughly 100 miles is good enough for my daily commute.
