Awesome video from Clearnwatt, and I gave up my Cybertruck range estimator career because he killed it
TLDR, with the efficiency Tesla has over similar competitors plus 4680 V2 which might be close to the the initial 98 Wh expected, a single layer 100 kWh pack for 300 miles of range and a double layer 200 kWh for 600 or close to 600 miles of range
Imagine a Cybertruck that is double the efficiency of a Hummer EV, can tow more than Lightning can go not towing, and charge in under 30 minutes, maybe even sub 20 minutes
It will be a better road tripper while towing than similar vehicles not towing
Only people that wouldn't get it over other EV trucks is the ones that are so hell bent on not liking it because else, it's what Franz said in the last interview, why would you get something else that is less safe, less capable and likely paying more for it?
I just disagree on the disengage able motors from Semi tech making it's way into it
For Semi you need to spin the motors fast to be able to keep them from overheating over long climbs at full power, the two acceleration motors have a steeper gear ratio for that
You don't need that on the Cybertruck, and for Tesla, adding motors barely hurt range, for example, Model S LR vs Model S Plaid with the same wheels. Adding a whole new motor and gear reduction loses you a whopping 9 miles of range, not worth the complexity of having a clutch to disengage one or two motors
