That aligns with Fremont cutting back to 25% staffing. Doesn't mean it's not assumed though.There's no linked source and I think the 75% bit is oldish news around here (as is all the rest), but it's in the main media, so might be used to further pressure the price down tomorrow
What if:
User sees red light. Autopilot doesn’t see any light. User assumes autopilot will stop, as it has done so correctly the previous 1000 times.
Perfect is fine.
Bad is fine as user will remain alert.
Nearly perfect is bad as user will forget their responsibility.
The car indicates distance to traffic control device, so the driver could see that the car does not see. (Better than with humans) Driver should also notice lack of deceleration.
If the detection is tied into the map database, then the most conservative approach is to treat every intersection as controlled. In that setup , you would need both a vision and a GPS/Mapping failure to induce your scenario, along with driver inattention.
