5/6 = 0.83is it going to make a major difference between 50 amp vs 60 ?
Almost everyone thinks they need higher power at home, just because the HPWC can accept higher power. At home I have lived happily with 30/208 for four years, meaning 23 amps and ~200 volts in practice. I almost always stay at home for 10 hours or more overnight and never have needed more power. Once you become accustomed to plugging in every night you'll find you might even want to dial back on the amperage to keep charging at a modest rate, thus avoiding any passive battery drain at all. Very often I dial back to 10 amps or so, for that reason.Awesome Thank You Everyone, This helps a lot. So yeah Plus I think Tesla has plans to add a supercharger near my house in few months so I can live with 50amps for sure.. I think and Just charge at supercharger if need it any faster.. Thank You So much for all your wonderful help what a great community we have so helpful !
Human nature is such that we start to notice differences above ~1/3 or some 30%.
Smaller changes get increasingly hard to notice without paying special attention.
5/6 = 0.83
The 50 Amp solution will be 17% slower
Phrased another way, you will spend 6 minutes charging on the slower solution instead of 5 minutes with the faster solution.
Wow! That is the most packed density panel I have ever seen. Literally every single breaker position already is "tandemed" up. The inside of that thing must be packed!
Your electrician is correct. The highest amperage "quad tandem" breaker Eaton makes is 50a. Something like this:
Eaton - BQ2502115, Quadplex Circuit Breakers, Residential, Power Distribution - Platt Electric Supply
I would probably still do the Wall Connector but just do it on a 50a breaker. The charge rate will be only 8 amps different. Still will be a little faster than just a UMC Gen 2.
If you have LED lights in the house and if some of those circuits are for lighting only, ask your electrician if you may be able to combine two on one circuit breaker. That layout was designed for incandescent lighting and would draw nowhere near 15a with LED's.
Fun with numbers: The 60 Amp solution is 20% faster than the 50 Amp solution.I agree it will be only like 17% Improvement
Minor nitpick. It's actually 48A vs 40A for 60A and 50A circuits, respectively. Sustained load should be no more than 80% of breaker size per code. Still a 20% difference though between the two.Fun with numbers: The 60 Amp solution is 20% faster than the 50 Amp solution.
Why ?
5*1.2 = 6
But looked at the other way
6*0.83 = 5
It would be a rare person who charges more than 20 kWh at a time and is watching the clock. I say this because once you have 20 kWh in the battery, you take off to the first supercharger en-route. It takes about 110 minutes to add 20 kWh to the battery at 60 Amps and 110*1.2 = 132 minutes at 50 Amps. So the very unusual corner case is a 22 minute additional delay.
However, this corner case can be almost entirely avoided by just having a daily routine that keeps your SoC over 20%. By doing so you have at least 60 miles of range for emergencies, and any long trip out of the blue where you waiting for the car to charge to 20 kWh before setting out would now be 22 * 6 /20 = 6 minutes additional delay from the slower charging choice.
If you live closer than 100 miles to a Supercharger that is en-route then there is no corner case at all.
Why ?
5*1.2 = 6
6*0.83 = 5
Yep. The time ratio remains the sameStill a 20% difference though between the two.
There are times when it’s convenient to have fast charging at home. The cases rarely justify radically higher Installation cost.If you live closer than 100 miles to a Supercharger that is en-route then there is no corner case at all.
Further, more and more shopping centers, restaurants and other facilities are adding J1772 and/or other charging options. Even a 120V wall plug gives 4-5 mph charge and that helps more tahn you'd think. I plug in those went at movies or restaurants when I see them. They simply add a little bit of charge, so you'll find over item that you'll plug into whatever you find wherever it is. It's a mindset change from thinking of 'refueling' as lost time.
For the record I agonized over charging when I first was driving Tesla in 2014. Now I only need to think about it when driving in remote areas, like Northern Ontario, even there the Trans-Canada-Highway has available charging options alreafy, and Superchargers are coming also. I thought I needed more power at home...luckily I gave up on paying for charging speed I did not need.
Doubt that maximum HPWC charge rate stresses battery at all. It is a small fraction of SuperCharger speed.Plus, charging batteries slower, at lower amperages is actually much less stressful to them and makes them last longer...FWIW.
