no, its clean title.Assume this is something you understood when purchasing at auction?
is it a salvage title?
It will not allow me to charge it. Wont open the charge port.Sounds like the battery is dead.
Have you tried charging?
I did take it to Tesla, they wanted 4k to fix it and no guarantees that it will fix it. So I want to try to fix it my self. Yes it has warranty but they said the accident it had caused the issue. but they will not tell me the issue or what needs to be fixed. total BSWhy aren’t you just taking this to Tesla to fix?
If it isn’t a salvage title then it has to still be under warranty...
The reason I did not write the whole story, honestly I didn't think anyone would respond on here but here it is.Please tell us more about the accident. Visible and suspected damage?
just added some more details aboveDepending on the accident they may not know until they get in there, but this is why it helps to know the whole story, not just 'Tesla won't start' - would never have suggested warranty work if you'd said it was crash damaged.
How bad is the damage and where?
I did not put a new 12 volt battery in it. The car has 2000 miles on it and the battery seems to be fine. nothing else got damage but the wheel and the knuckle, since it got pushed back It cut open the two High Voltage wires and that most likely blew the Pyro Fuse. everyone else is working properly.The pyro fuse can be tested with an ohmmeter. I don’t *think* it would partially fail.
You put a new 12v battery in it?
did any of the cooling system get damaged?
motors?
