this is what the logs say:
root@docker-s-1vcpu-1gb-ams3-01:~# docker-compose logs
Attaching to root_teslamate_1, root_database_1, root_grafana_1, root_mosquitto_1, root_proxy_1
database_1 |
database_1 | PostgreSQL Database directory appears to contain a database; Skipping initialization
database_1 |
database_1 | 2020-09-11 23:13:32.861 UTC [1] LOG: starting PostgreSQL 12.4 (Debian 12.4-1.pgdg100+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.3.0-6) 8.3.0, 64-bit
database_1 | 2020-09-11 23:13:32.877 UTC [1] LOG: listening on IPv4 address "0.0.0.0", port 5432
database_1 | 2020-09-11 23:13:32.877 UTC [1] LOG: listening on IPv6 address "::", port 5432
database_1 | 2020-09-11 23:13:32.888 UTC [1] LOG: listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
database_1 | 2020-09-11 23:13:32.974 UTC [24] LOG: database system was shut down at 2020-09-11 23:13:03 UTC
database_1 | 2020-09-11 23:13:33.003 UTC [1] LOG: database system is ready to accept connections
database_1 | 2020-09-11 23:18:08.627 UTC [58] FATAL: role "teslamate" does not exist
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Starting Grafana" logger=server version=6.7.4 commit=8e44bbc5f5 branch=HEAD compiled=2020-05-26T17:35:38+0000
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config loaded from" logger=settings file=/usr/share/grafana/conf/defaults.ini
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config loaded from" logger=settings file=/etc/grafana/grafana.ini
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.data=/var/lib/grafana"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.logs=/var/log/grafana"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.plugins=/var/lib/grafana-plugins"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from command line" logger=settings arg="default.paths.provisioning=/etc/grafana/provisioning"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from command line" logger=settings arg="default.log.mode=console"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_PATHS_DATA=/var/lib/grafana"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_PATHS_LOGS=/var/log/grafana"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_PATHS_PLUGINS=/var/lib/grafana-plugins"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_PATHS_PROVISIONING=/etc/grafana/provisioning"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_SERVER_ROOT_URL=
https://dograf.example.com"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_ANALYTICS_REPORTING_ENABLED=FALSE"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_SECURITY_ADMIN_USER=admin"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_SECURITY_ADMIN_PASSWORD=*********"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_SECURITY_DISABLE_GRAVATAR=true"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_SECURITY_ALLOW_EMBEDDING=true"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_USERS_ALLOW_SIGN_UP=false"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_AUTH_ANONYMOUS_ENABLED=false"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_AUTH_BASIC_ENABLED=true"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Path Home" logger=settings path=/usr/share/grafana
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Path Data" logger=settings path=/var/lib/grafana
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Path Logs" logger=settings path=/var/log/grafana
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Path Plugins" logger=settings path=/var/lib/grafana-plugins
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Path Provisioning" logger=settings path=/etc/grafana/provisioning
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="App mode production" logger=settings
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing SqlStore" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Connecting to DB" logger=sqlstore dbtype=sqlite3
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Starting DB migration" logger=migrator
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing HTTPServer" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing BackendPluginManager" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing PluginManager" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Starting plugin search" logger=plugins
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Registering plugin" logger=plugins name="Pie Chart"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Registering plugin" logger=plugins name="Map Panel"
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Registering plugin" logger=plugins name=Discrete
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Registering plugin" logger=plugins name=TrackMap
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing HooksService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing OSSLicensingService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing InternalMetricsService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing RemoteCache" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing RenderingService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing AlertEngine" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing QuotaService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing ServerLockService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing UserAuthTokenService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing DatasourceCacheService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing LoginService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing SearchService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing TracingService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing UsageStatsService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing CleanUpService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing NotificationService" logger=server
grafana_1 | t=2020-09-11T23:13:31+0000 lvl=info msg="Initializing provisioningServiceImpl" logger=server
grafana_1 | t=2020-09-11T23:13:32+0000 lvl=info msg="Initializing Stream Manager"
grafana_1 | t=2020-09-11T23:13:32+0000 lvl=info msg="HTTP Server Listen" logger=http.server address=[::]:3000 protocol=http subUrl= socket=
grafana_1 | t=2020-09-11T23:13:32+0000 lvl=info msg="Backend rendering via phantomJS" logger=rendering renderer=phantomJS
grafana_1 | t=2020-09-11T23:13:32+0000 lvl=warn msg="phantomJS is deprecated and will be removed in a future release. You should consider migrating from phantomJS to grafana-image-renderer plugin. Read more at
Image rendering" logger=rendering renderer=phantomJS
mosquitto_1 | 1599866012: mosquitto version 1.6.12 starting
mosquitto_1 | 1599866012: Config loaded from /mosquitto/config/mosquitto.conf.
mosquitto_1 | 1599866012: Opening ipv4 listen socket on port 1883.
mosquitto_1 | 1599866012: Opening ipv6 listen socket on port 1883.
mosquitto_1 | 1599866012: mosquitto version 1.6.12 running
mosquitto_1 | 1599866030: New connection from 172.20.0.6 on port 1883.
mosquitto_1 | 1599866030: New client connected from 172.20.0.6 as TESLAMATE_302E3732323 (p2, c1, k60).
proxy_1 | time="2020-09-11T23:13:32Z" level=info msg="Configuration loaded from flags."
teslamate_1 | 01:13:38.069 [info] Already up
teslamate_1 | 01:13:48.313 [info] Version: 1.19.4
teslamate_1 | 01:13:49.224 [info] Refreshed api tokens
teslamate_1 | 01:13:49.224 [info] Scheduling token refresh in 40d
teslamate_1 | 01:13:49.232 [info] Running TeslaMateWeb.Endpoint with cowboy 2.7.0 at :::4000 (http)
teslamate_1 | 01:13:49.233 [info] Access TeslaMateWeb.Endpoint at
http://dobeta.g358xh.nl
teslamate_1 | 01:13:50.068 [info] Starting logger for '** BATTERY LOW **'
teslamate_1 | 01:13:50.089 [info] MQTT connection has been established
teslamate_1 | 01:13:51.007 car_id=1 [info] Start /
ffline
teslamate_1 | 01:13:52.014 [info] tzdata release in place is from a file last modified Wed, 11 Sep 2019 19:35:17 GMT. Release file on server was last modified Fri, 24 Apr 2020 04:15:20 GMT.
teslamate_1 | 01:13:53.902 [info] Tzdata has updated the release from 2019c to 2020a
