Russinating
M3 SR+
Ah the pointy clicky stuff - ssh CLI all the way (I'm from the vi generation)
"real men don't use menus"
That's fair, but some things are just quicker and easier via GUI .
If the port is already allocated, there's another service using it. Are you perhaps trying to start Teslamate twice?
You can run the command "netstat -ltpn" to check which process is currently using each port.
Here you goCan you run that again as root? The output is incomplete, apologies I should've specified that in my earlier message.
"sudo netstat -ltpn"
Brilliant, many thanks, will have a go at that and see what I can get goingOkay, so then as expected there's already an instance of teslamate running - which is why it's throwing the error you're seeing when you attempt to restart it. You mentioned in your earlier message you've already tried restarting your Pi, but I presume you have a script which is starting your docker containers on boot.
If you run "docker ps" you will see the instances currently running (and the ports they're using), you can force them to stop by running "docker kill xxx" where xxx is the container ID shown in the "docker ps" output. You can then try re-starting it using "docker-compose up -d".
I've had this problem sporadically, since I've owned my TM3, through all the sorts of firmware updates. Anybody notice that their TM3 stays awake for an unbelievably long time (8 hours after a very short drive yesterday) sometimes (and I've checked that all the doors, etc... are closed)??? I'm not blaming TeslaMate, it just allows me to easily see it happening instead of walking to the garage and hearing the car lightly humming.
View attachment 537709Seems excessive, mine is online two hours after most drives then sleeps. Occasionally quicker but 8 hours never. I take it you are locking the car (or autolocking) and not using sentry mode?
You don't need to buy a domain you need either a static IP of a Dynamic DNS supplier (I use Remote Access with Dynamic DNS - 100% DNS Uptime - No-IP)Hi all
I'm very interested in this topic.
I don't have my model 3 yet but this looks like something I really going to install once I have it. I do have a question though.
When you install TeslaMate on a Raspberry Pi with the easiest installation, I do understand that you only can access it via the home WiFi where the Raspberry Pi is connected to.
If I would like to connect it from everywhere, I see that you need 2 URL's. So I would need to buy myself a domain (and there I can make a subdomain to have the 2 URL's I suppose)
Now the question really is: Should I buy only the domain and link these to the IP address of the Pi, or is it possible to use a domain name I already have? This domain name is bought with webhosting included. So not only the domain name but also web hosting and things combined.
Is it possible to use the already owned domain name but both link to the Raspberry and the already existing webhost from the company I bought the domain name from. Or should I really buy a new domain name for the TeslaMate?
Thanks a lot for the help!
You only need to buy a domain name if you’re planning to access it over the internet
Sorry, yes, you’re correct in that you can use one of the many dynamic DNS services as well.
I’m not sure example 1 will work with the default config, since it expects you to set up two FQDN for teslamate and grafana.
