The first commercial solid state batteries are in production
Discussion in 'Battery Discussion' started by Phrixotrichus, Nov 21, 2018.
  1. Phrixotrichus
    Phrixotrichus Member
    Germany
  2. OPRCE
    OPRCE Member
    Bern, CH
    The only technical detail in the article is "energy density of over 400 Wh/kg", which sounds encouraging when compared to the 268 Wh/kg estimated for M3 21700 cells, but we will need to know about cycle life, charge rates, manufacturability, etc., before getting too excited about this announcement.
  3. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    FTFY :D
    I think that high-density batteries will have applications, so it's still good to see them in production.
  4. OPRCE
    OPRCE Member
    Bern, CH
    Certainly, though if for example cycle life is limited to 300 then it will never be much use for cars, despite the improved energy density, unless it can be made extremely cheap and replaced every 2 years.
    Nevertheless very interesting to see what will pan out here ... best of luck to them!
  5. ItsNotAboutTheMoney
    Maine
    Right, cycle life is a cost issue: cost of battery, cost of replacement.
