I want to ask the techies of the group the following.....
If the new 60 is actually a software limited 75 pack, would it supercharge at the same rate as a 75 pack?
also if i were to 100% charge it, wouldn't that only be somewhere between 80-90% of the packs total capacity and there for not suffer from Overcharge burning the pack if I were to 100% charge daily.
Reason for the questions is i am range concerned that as the pack ages i will fall below my daily drive cutoff amount of 150 miles on he 60 pack, vs a used 85 which should stay above the line for quite a while. Also the later upgrade while expensive could also keep me above the line.
Thank you
Thank you
