webbah
Fair point and good for people to be aware. The tires themselves matter as well. One of my friends is running 18’s with the Sottozero 3’s and his car is noisier than mine. He was astonished. I’m running Michelin Pilot Alpin PA4’s and find them to be excellent both for handling in winter and noise if setup properly. I’ve done some dB testing and was able to reduce from an average of 70-72 dB at 120km/h to 66-68 dB’s. This doesn’t sound like a lot, but it is very noticeable at highway speeds. Only thing I’ve done is add Bassenor door seals, RPM top window seal and adjust the tire pressures. As mentioned previously I also changed to coilovers (Unplugged Performance) and on the comfort dampening it’s quite a nice ride even with 20’s. On the track I drop down to 18’s though.I thought that too. RWD Model 3 with 18" Aero's is still 45 psi. AWD 18" is 42 psi. I don't think it ever changed. I think folks might have got confused when AWD was introduced with 18" wheels at 42 lbs. And yeah Elon mentioned dropping them to 42 early on, but I don't think they changed any door tags.
I'm not saying 38 psi is too low or unsafe, I have no idea, I just wanted folks to know you are changing the load capacity of the tires when you lower the pressure.
I always try to stick with what the door tag says.
I got rid of my Model 3 partly due to its harsh ride. I love how Model X rides. No longer paranoid when approaching a speed bump
