Third Brake Light on Dashboard Not Lighting Up
Anyone notice on 2023.6.1 that the third brake light doesn’t light up on the dashboard when you press the brakes or go into regen?
Also on the new mini window vehicle box on the MCU, the turning indicator lights up when pressing the brake as well.
What’s going on here? Software issue?
Maybe your third brake light is not working on the car. Otherwise, it is a software issue with the displaying of the third brake light. Check your lighting for problems and let us know.
Third brake light is functioning normally.
Service center verified the situation, did a low voltage test and looked at the wires but everything checked out.
They believe it is possibly software related and probably will be corrected on the next update. But they escalated it to region to see what can be done.
