Doesn't the Tesla cut back the amperage it is using if it sees a drop in voltage? Maybe that's why @ecarfan hasn't seen a problem when using both the trailer and car charger at the same time -- the Tesla sees a voltage drop when the heater or a/c cuts in on the trailer and dials back?As noted by DCGOO is the main reason. The NEC allows circuits to be "derated" in certain conditions. I'm not sure but a stall may in fact share one circuit to feed all the outlets in that one bay. So the 50 amp plug would be 100% rated and the 30 AMP might be shared on that same 50 amp outlet. I'm not sure, but the main panel downstream is definitely derated. They are not expecting a lot of power to be consumed by a single trailer. So they allow percentage drop at the main panel based on how many camp sites are there. The more sites the larger the derating. It usually works for all the campers. Have a bunch of Tesla's show up and start charging breakers are going to start popping at the main panel. Plus the wiring will start deteriorating over time.
Did you guys add brake controllers to your cars? I'm running electric brakes on the trailer and still want them. I don't have a surge brake on my trailer. Test driving this morning i still have the regen stopping the car, but want them for insurance.
