Towing trailer emergency
doghousePVD
My grandfather’s car
Dec 3, 2018
884
889
New England, USA
Away from home. Can’t tow travel trailer.
Took off trailer to Supercharge. After reconnecting trailer, all trailer lights stopped working. Also had low brake fluid errors, and brake pedal fully depressed much more than usual. Had red trailer icon, then changed to yellow.
Cleaned all trailer connectors, same results. Towed trailer with no lights or brakes carefully to friend’s house in daylight.
Testing today showed trailer icon alway on regardless if trailer connected. Icon color can change from blue to yellow with Trailer Mode switch. No red icon. No more brake errors.
Tesla connections look very clean.
Tested Tesla trailer plug. No voltages at any pair of terminals, including + and - . Had car on, all lights, flashers.
Checked fuse #105 in frunk with ohm meter. Removed and visually inspected. AOK. Ohm test all fuses in frunk fuse box, all ok.
Have done 4 finger/brake reset, Power Off, and Reset Wheet Configuration.
Nothing now is able to turn off yellow towing icon. (Except turning on towing becomes blue). No hitch in receiver.
Any suggestions?
Hi @doghousePVD ,
I have noticed my trailer icon sometimes remains lighted after disconnecting my trailer.
When the trailer mode switch does not work, I take a brief drive without the trailer.
This sometimes resets and turns off the trailer mode light...
Good luck,
Shawn
