Any car that doesn't work or meet your expectations will for sure irritate you, it would for me, so I understand where you're coming from. As for my opinion that the 1.5 is better is based upon my opinion which is biased for that I have a 1.5, but also being an engineer, I can see and appreciate how this car was built and truly put it out there as an engineering marvel. The 1.5 had to be built solid since this was prove your design works or forever hold your peace and walk away type of stage for Tesla. Granted the 1.0's had their fair share of issues, esecially with the gearbox that was resolved in the 1.5 version. Not to many people had the 1.0's at that point, so the impact was minimal on the customer. Anyways, with the 1.5 I also worked with the purchasing agent who bought all the parts for this car, and they really didn't spare too much of an expense on things early on. However the 2.0 was a cost cutting version, yes there were some minor improvements, but what I can see there were things that gave the customer a really bad experience. Crappy TPMS system, which the only positive part was that you had tire-learning. So that in a sense was an upgrade that gave unreliable results. PEM cooling was improved and the PEM underwent a little bit of a redesign, but with that the cooling was good at the cost that it clogged up regularly with road debris and leaves. The 1.5 CF center console and shiftier was replaced with a faux leather console and push button gear selector, all which cut costs. Tesla did the cost cutting in order to make their investment dollars go farther and to survive which proved to work as we look back today. But any car can turn into a lemon, just bad luck, bad timing having multiple parts fail over and over again, even the 1.5 is not immune to that in my opinion as well
Sometimes if you have a car that gives you grief is to just get out from under it and sell it. Possibly pick up another in the future and do more research in the history, ownership, and maintenance records of the car before you do purchase it. This will at least give you the upper advantage when buying a car.
