My guess is that the M3 is set up similarly to my first MS - S85. In spite of all the talk about immediate torque, indeed the S 85 did not put out enough kW to the motor from a dead stop and felt stronger once going at 30Mph or so.
That's in start contrast to my new P100D. I understand the "P" comes with higher rated PM (inverters) to allow for full and immediate power delivery.
Yes, it's just a sum of forces calculation. I assumed a rigid vehicle (no axle squat from suspension).How do you calculate this? Seem like it would depend on center of gravity, spring rates, etc.
It's limited by the motor controller, not the pack. The pack has a power limit (kW) which it is nowhere near at 20 mph (look at the graph). S85, Model 3, etc. don't generate maximum power until 45mph. The original P85 didn't have that much more power than the S85 but it had a lot more torque. That's all through changes to the motor controller and motor but since it only had 414hp vs. 362hp they probably didn't have to change the pack much.Yes I agree. I often compare it to the S85 VS the P85. In the end they feel the same, just the S85 is limited from about 0-20 on how much it can pull from the pack. If there was a way to make it more like a P85 I would be a happy camper.
Interesting. I guess suspension would only increase the transfer to the rear. Thanks!Yes, it's just a sum of forces calculation. I assumed a rigid vehicle (no axle squat from suspension).
Other assumptions:
- CG height: 18" (est)
- wheelbase: 113"
- 3 LR weight distribution: 48% Front, 52% rear
- CG longitudinal position: 59" [113*.52]
Rear wheel load at +0.6g: (59+0.6*18)/113 = 62%
This video helps derive the equation:
Sorry, I'm an electrical engineer. It's hard for me. haha.Im pretty sure the motor controller pulls from the pack, which makes my statement valid. You do not need to be so technical. This is a forum not an engineering firm.
The limit on the battery is how much power can be drawn from it. You can see from the graphs that the motor is not drawing very much power at low speeds so there is no way for the acceleration to be limited by the pack at low speeds.
Carbon offsets. Need to offset carbon saved by EV with carbon from tires.And why does it need to spin out? I have never needed to, and have felt it lessens my control. You already know it could, but it seems Tesla figured safety was more important.
I know. I'm no fun. But wifey likes me.
You have obviously not driven an EV or at least a Tesla. I have taken my Roadster to the track and NOTHING beats it off the line, and very few cars catch me in the 1/4 mile. There is no wheel spin due to good traction control, but have no mistake they will launch well.My guess would be that the Model 3 does not generate enough torque to the wheels to spin the wheels. This is because it has a flat torque curve almost all the way to 60 mph and a single speed transmission. RWD ice vehicles with similar 0-60 times can spin the wheels because they have faster acceleration (more torque to the wheels) in 1st gear. While the ICE vehicle would beat the Model 3 off the line the Model 3 would catch up after the ICE vehicle shifted into second gear. Obviously this is in drag race type conditions. The ICE vehicle would have to rev the engine and feather the clutch (or load the torque converter in an auto) to achieve "magazine" 0-60 times. All the Tesla driver has to do is push the accelerator to the floor.
I've only driven an Model S 60 for any length of time (The slowest Tesla ever made!). It is nowhere near as fast off the line as my Subaru Legacy GT (hard to beat turbo+AWD). I also test drove an P85D and that was definitely quicker though!You have obviously not driven an EV or at least a Tesla. I have taken my Roadster to the track and NOTHING beats it off the line, and very few cars catch me in the 1/4 mile. There is no wheel spin due to good traction control, but have no mistake they will launch well.
It takes the same amount of torque to spin the wheels at 0mph as it does at 40mph though. So if you're accelerating at 40mph and not spinning the wheels then even if you have the same acceleration (torque) at 0mph you will also not be spinning the wheels.Indeed its a dyno graph. It looks like the car was on and running with motor doing 4000rpm when they hit the throttle. But my point was that the way the torque then rises is just how it felt on my old S 85 - rising quickly, but not instantly. The car felt stronger when punching it at about 40mph (which ties to 7000 rpm).
If that's the way it also is on the M3, then it can explain the lack of wheelspin.
Wind resistance is not significant to acceleration (it is to efficiency): https://www.tesla.com/sites/default/files/blog_attachments/the-slipperiest-car-on-the-road.pdfSure, but only if you were in a vacuum. Wind resistance at 40mph is significant. But the point is that in my old MS85, I experienced non-linear, ramping acceleration - unlike in my P100D. This is not about theoretical Newtonian physics, but about the power being able to be delivered by the drive module over time in response to the throttle.
And BTW there are many ICE's that pull cleanly away from my MS once at speed (they just can't get off the line like the P100D)
Respectfully, at 40 mph, that’s just incorrect. Basic physics - and common sense. Put your palm out the window at 40mph. The Model S is indeed otherworldly in some respects but must still abide by the laws of our universe.Wind resistance is not significant to acceleration (it is to efficiency):
4.6hp is a lot of power! Horses are a lot less aerodynamic than a Model S and they can run pretty fast. haha. This is from Tesla's own website.Respectfully, at 40 mph, that’s just incorrect. Basic physics - and common sense. Put your palm out the window at 40mph. The Model S is indeed otherworldly in some respects but must still abide by the laws of our universe.
Again, while the motor may be capable of producing immediate torque, it would seem the non P modules do not deliver full power immediately on throttle, which explains this behavior on the regular S and likely also on the Model 3.
Honestly, Daniel, I prefer to rely on on my own thinking and training.This is from Tesla's own website.
