AlanSubie4Life
Efficiency Obsessed Member
@Nate977p
Did a quick check on my way home tonight (it is uphill so consumption is a little high). I stopped at the store, so it is in two segments. Note I did not use HVAC for this one so that is something to consider if your other numbers don’t align well (but I don’t think it matters). Another thing is that the car had just been charged, so it definitely was not cold-soaked, though regen was limited due to the high SoC of 95% starting point. I also launched the car once to 60mph, just to get a brief very high current event in the discharge profile:
Start 293 rmi
End 280 rmi
Segment 1: 4.7mi, 279Wh/mi. End 288 rmi
Segment 2: 4.8mi, 393Wh/mi. End 280 rmi
Summary :
Rated miles:
Consumed 13 rmi, 242Wh/mi = 3.15kWh
vs. trip meter:
4.7*279 + 4.8*393 = 3.20kWh. (Really there are only two significant figures here, so 3.2kWh would be more correct..the rated miles product is also just 2 sig figs, so that is also 3.2kWh.)
So that all seems to align pretty well (1.5% high on the trip meter, though almost certainly due to rounding error on the rmi). For two sig figs it is exactly the same.
This is a super short run, not a good example of how to do this, so the result easily could have been off by 250Wh due to rounding error, but happened not to be. Long drives would be much better so that you could get the results to three significant figures. (You need a rated miles change of greater than 100 miles.)
I noticed that I got out of the car at the grocery at 287 miles, but when I came back to the car it was at 288 miles. So pretty easy to have an error of a mile or two which for short runs would be significant due to this minor jumping of the rmi.
Start 293 rmi
End 280 rmi
Summary :
Rated miles:
vs. trip meter:
