AlanSubie4Life
Efficiency Obsessed Member
Thus with my math, I used 26 miles to go 18.1. Meaning my efficiency was about 69% (quick math, think I did that right). But my car only indicated 316 Wh/mi. If the baseline efficiency for the car at rated range is 250 Wh/mi, wouldn't 69% efficiency be about 362 Wh/mi?
Getting back to your point:
So using the numbers above, I would say:
26*250 = x * 18.1 => x = 359Wh/mi is what you would expect the trip meter to read.
However, the numbers are wrong. First, use baseline efficiency of 242Wh/mi. Second, let's just say (to get things to align ) that you only used 23.6 rated miles (2.4miles less than what you stated, for fudge factor reasons I stated earlier). Admittedly, I am just fudging your numbers to make it work here.
Then:
23.6rmi*242Wh/rmi = x * 18.1mi => x = 316Wh/mi
23.6 rated miles to go 18.1 (76.7%)
316 Wh/mi vs. rated 242Wh/mi (76.6%)
Can I really burn almost 8kWh by parking overnight in a garage at about 60, and then outside for 8 hours in 30? That would mean if I left my car sitting in an outside lot for a day, it would fully drain.....
Are you sure of what your initial mileage was? In answer to the above question, you certainly can burn a few kWh overnight in the right scenario due to vampire, and if temperature of the pack changes a lot (maybe it was really warm after the supercharge), etc., that can cause the BMS/SoC estimator to change the miles available quite a lot. In short, there isn't really enough information here to tell. We really need to know the starting mileage when you got in the car (when the trip meter actually started - I understand you were using the last charge meter in this case, but for science, let's remove some variables like sitting overnight). 8kWh is a lot though. A lot of it is real unfortunately....
Next time you have an opportunity, post some data (pictures at beginning and end of drive) with a more controlled experiment. And we can go through the numbers again. As part of the experiment, please be sure to turn OFF climate control before exiting the car the night before the experiment. You can turn it on again as soon as you take the car out of park (but be sure to turn it off again every time before going back to park). Also don't spend any time in the car in park. After making these adjustments, let's try calculating again. Longer mileage runs like the one you posted above are ideal.
As I said, I agree the trip meter (and since last charge meter) is garbage. It makes this sort of exercise an exercise in futility unless you tightly control the conditions (which should not be necessary). It's just kind of dumb.
For vampire (not counting any preheating losses, etc.), just add 400kWh/(your miles traveled per year) to your efficiency numbers. So if you're doing 20k miles per year, add 20Wh/mi to your wall-to-wheel energy costs. It's approximate, but close.
