wws
Thank you for sharing. I tried a straight forward charge yesterday with my new ccs adapter and had no luck but hopeful to try autocharge+. Curious what your max charge rate was?
Sorry for the late reply. I've seen peaks in the 170-180 kW range on CCS at 350 kW EA and EVgo chargers. The EVgo station I tend to use for testing is only 50 kW max. It is one that also has an attached Tesla CHAdeMO adapter. So peaks at low- to mid-40s kW - comparable to using the CHAdeMO adapter. These have been mostly functionality tests. Not intended to try for peak charging rates via deep preconditioning and low states of charge.
