bdy0627
Those puts were expensive leading up to the ER. Even with the huge drop in the stock price, they are only at breakeven right now. Crazy.
I’d be extremely careful selling calls now. Once they get the M3 production worked out the SP could jump spectacularly.This is my current strategy:
I am long TSLA common (long term investment), plus some OTM LEAPS for leverage.
I am selling weekly OTM calls and puts with an initial delta of 0.2 or less. More calls than puts. The time decay on those more than offsets the time decay of the LEAPS plus makes me some money. Whenever these short calls run ITM, I roll them out (one, max 2 weeks) and OTM, usually for credit. Thanks to the amazing option premiums this is currently working very well.
Market may react quickly to perceived increased production numbers inferred through large numbers of Model 3s showing up on the market. Also, EM could tweet something significant about production. Remember, he enjoys crushing the shorts. Those are the main risks to betting on either the downside or neutral for the next month.do you think we're likely to get any more info on this before end-of-quarter/end-of-december when deliveries are announced? i would think the next 3-4 weeks would be pretty quiet news-wise.
I think that Tesla needs to produce at least 1.5k per week by the EOY to avoid a substantial SP dip. A problem with trying to gauge their progress is that they are likely to hit that (if they do) within a few days plus or minus of the EOY. In other words it might be impossible to “perceive” their production.Market may react quickly to perceived increased production numbers inferred through large numbers of Model 3s showing up on the market. Also, EM could tweet something significant about production. Remember, he enjoys crushing the shorts. Those are the main risks to betting on either the downside or neutral for the next month.
Other ideas are to sell calls against your long calls to create a call spread, butterfly off your calls (short 2 higher strike calls and buy one higher than that), or just sell a portion of calls for cash and let your current calls run. All of these will give you cash while maintaining some upside potential. When it comes to options, I've personally found that the best trading strategy for me is anything that puts more cash in my account. When you have cash you have choices. When you don't have cash you are much more limited in what you can do. You may miss out on some gains if all of your cash is not at work but as long as you have cash you can play "the game" and there will always be more trades to make with cash you have.I need some options suggestions. I'm nearing the point where I will have a good but difficult problem: when to sell March, April, and then June Calls. I thought I had a really good strategy for our downtrend. I bought the hell out of it, especially below $320. That was easy. My account was down big by the end of December. Now, I've had the best January ever by far. My account is getting close to where it was last summer at the high. I don't want to be overly greedy and pay the price. I plan to buy J19 LEAPs with most of the proceeds from selling these nearer term Calls. It would be ideal to sell them on the rise when premiums are high, and then buy J19 LEAPs when they have settled down. However, that involves a lot of luck with waiting for a dip after selling the Calls I have, hoping the stock actually gives me a dip. In reality, I may just sell these and immediately buy J19s. I think the best approach for me will be to do this in waves on the rise. Any suggestions from others who have done this and/or are planning something similar? After selling nearer term Calls, do you try to time purchase of LEAPs during some stock consolidation so implied volatility and premiums settle down? Or do you just go straight over to the longer dated Calls?
Here would be a "normal" butterfly to compare with. Long the $325 and $375 and short 2 $350s.Other ideas are to sell calls against your long calls to create a call spread, butterfly off your calls (short 2 higher strike calls and buy one higher than that), or just sell a portion of calls for cash and let your current calls run. All of these will give you cash while maintaining some upside potential. When it comes to options, I've personally found that the best trading strategy for me is anything that puts more cash in my account. When you have cash you have choices. When you don't have cash you are much more limited in what you can do. You may miss out on some gains if all of your cash is not at work but as long as you have cash you can play "the game" and there will always be more trades to make with cash you have.
If you don't like having a chunk of cash (hard to get used to force yourself to follow but I highly recommend it for trading options) then you can put your proceeds into neutral strategies. You can buy calendars or put butterflies with a target strike below where TSLA is trading right now. These will lose if TSLA keeps going up but will make you money if it only goes up a little, stays the same, or goes down. One special type of butterfly strategy called the broken wing butterfly will actually make money if the stock goes up, down, or stays the same and only loses money on a huge run to the wrong direction. The negative of this strategy is the larger margin requirements than other defined risk trades.
Because most people probably haven't heard of the broken wing butterfly here's one example (not recommending it but wanted to give an idea). I chose $340 as the short strike beause Option Sniper said we will revist $341 in February. You can shift the strikes around to suit yourself, the key to the broken wing butterfly is to take in a credit on order entry. In this case, you would go Long 1 February $290 and 1 $355 puts and short 2 $240 puts. Putting on this spread gives you $236 up front. If TSLA keeps going up you keep that money until the spread expires or you close it out. You can not lose money on this spread if TSLA keeps going up. If TSLA goes down you will initially be red on the trade but as the date gets closer to expiration theta decay will occur and you will lose less and less until you are green on the spread. During the last week or 2 you will start to get very green! At this point you will be able to close out the trade for a credit! That's right, this is a trade that you can put on for a credit AND take off for a credit if you can pull it off. The only way you lose money on this trade is if TSLA ends below $322.64 third week of February. If TSLA expires between $330 and $350 you will do very well on this trade, though I wouldn't wait until expiration. I would take if off when you are happy with the level of profit you are at with it. The great thing about a strategy like this is you can use it to offset some losses on your calls if TSLA doesn't keep going up. If you bought ATM or OTM puts to hedge with and TSLA keeps going up or stays the same you lose 100% of that money. The negative of the broken wing butterfly is if TSLA really goes down you will lose a lot more than you could have made whereas puts could make you several times your investment (but rarely do). If you go out to March or April for your broken wing butterfly you can make the green triangle a lot wider and easier to hit or it will give you a lot more profit for the same strikes but in exchange you will have to wait a lot longer for theta decay to occur so I usually don't go more than 45 days out for these, at most 60 days. This is not an instant gratification trade like TSLA shooting up while you're holding long calls. There are tradeoffs with every strategy and no perfect obvious way to do anything...
