UHFS Audio - Front/Rear Fader Setting Will Not Stay Put
Discussion in 'Tesla, Inc.' started by habanero69, Nov 14, 2016.
Tags:
  1. habanero69
    habanero69 I Dont Need Cialis. I Drive an EV.
    FLorida
    I don't know if this started after the v8 upgrade or not, but I did not notice it prior. I also haven't figured out a pattern as to when it resets to mid point rather than about 70% towards the rear where I want it. Sometimes it seems like it happens during the day during one of my stops, sometimes it seems like only after a charging session. I just don't know at this point. Has anyone else noticed this? I assume it's a bug of some sort, as there is no setting that I could see that would influence it. I also assume no matter what the audio source, it should stay in the setting I want; it doesn't change based on source selection. When I get in the car and the audio comes on, I can immediately tell if the setting has moved back to exact center... I check and sure enough it has. Bumming me out... :(
  2. hmmm
    hmmm Member
    Driver Seat
    +1
    I don't recall seeing that pre v8 and can't find a pattern either. It *seems* like it's happening more when I switch sources more (but is not source-specific, but no clear pattern that I can find.
  3. Dithermaster
    Dithermaster Member
    Madison, WI
    I've only noticed this happening since 8.0. It's annoying to be sure.
  4. NikeWings
    NikeWings Active Member
    Mine seems to stay put if my last source was XM, but other sources move straight to center when I re-enter the car. :mad: Once I reset, it holds until I get out of the car and the cycle repeats itself. Dolby is inconsistent again too.
  5. Beavertail S
    Beavertail S Member
    Jamestown, Rhode Island, United States
    A bother for me too. I hope Tesla fixes it. Definitely began only in latest big update.
  6. O-G
    O-G Member
    Tacoma, Wa
    What about the equalizer settings? Mine keep reverting to -3.0 all across. Anyone found a fix?
  7. hmmm
    hmmm Member
    Driver Seat
