If you pulled this off, you might just have to be knighted!
How did you mount it ? Can you take a cheeky photo?
2 screws/rawlplugs.If you pulled this off, you might just have to be knighted!
The thing the head attaches to was something that went up with the Wallbox charge point, so I thought I would surround it with the cable winder. No need to use one, but I just found it a faff dealing with the rubber cover on the end of cable otherwise, as it is a very tight fit, which is why it just hangs there now.You absolutely nailed it @HenryT . What do you use to house the charge head or did it come with the wallbox?
In any case, I'm inspired. Brilliant. And thanks so much for the pic, really appreciate it. Cudos.
I got mine here Model 3: Logo Upgrade Emblem Decals (3 pcs, ABS shell)@Filbert1884 can you link the ones you got hold of? They look great. I have a white M3 cooking; due to arrive ~march. The ones I see on Amazon seem to be 'replacement' ones, which I don't want to do if you can get ones that just adhere to the existing ones. Yours look flawless. I wanted to get matt black ones if they do them.
I have this...Whilst here, has anyone tried or use one of these?
EV Charger Type 2 Wall Bracket for Charging Cable Wallbox Charging Station Charging Cable Organizer Charger Bracket Wall Connection Holder : Amazon.co.uk: Automotive
At first glance appear like a good buy for ~£25.
I think I was sold as soon as I was presented with the word : Stange
Been studying side by side pics and I wouldn't be surprised if they're identical. The difference is one is far more 'stange' than the otherI have this...
Type 2 Charging Cable Organizer, EVs Motors Wall Mount Connector Cable Organizer Bracket Charger Holder Adapter Fit most EU Standard Type 2 Charging Cable Organizer, EVs Motors Wall Mount Connector Cable Organizer Bracket Charger Holder Adapter Fit most EU Standard : Amazon.co.uk: Electronics & Photo
The thickness of the cable on the granny charger makes ensuring the cable is wound in a way so that the plug fits in the holder a little tricky sometimes, due to the resistance of the thick cable, but it's simple and does the job.
If it's the Tesla home charger you are buying then it doesn't come with a holster. The 'head' plugs into the side of the charger when not in use and the cable wraps around the body - see hereIdeally I wanted something to 'plug' the charge head in when it's not.. plugged in.. I know that sounds totally clumsy worded like that. It's an expensive and important bit of gear and wasn't sure if the actual housing came with the charge which it looks like it doesn't. The B&Q cable tidy looks great.. might have to research if the tesla charger does indeed come with some kind of holster (or not).
I’d just grab a couple of tins of the compressed air and goop to cover any punctures. They do expire after a few years but they are so cheap it’s not really a concern.
Any more than that you are looking at recovery anyway.
E.g. something like this
Holts Tyreweld 500ml | Halfords UK
Shop the latest Don't let a puncture stop you - Tyreweld gets you back on the road fast. at Halfords UKwww.halfords.com
That may have been something that could have been sorted out at the roadside, before the tyre wall was damaged if you had a plug kit and a means of blowing up the tyre?
Have you required to use this stuff on a foam lined "acoustic" tyre? I know it makes a heck of a mess in a normal tyre but I envisage a horrendous scene ... and most likely failing to seal the puncture into the bargain. I suspect that many tyre places would just refuse to get involved!
Yep, it's a killer if you need to drive even a very short distance on a flat tyre ... almost guaranteed to damage the sidewalls beyond future use. And in the case of pothole punctures the sidewall can be ripped anyway.Couldnt be repaired as although the (rather large) hole may have been able to be repaired, me limping to the garage on a flat tyre had cracked / damaged the sidewall.
