The strangest message keeps coming up on the instrument cluster when I press the brake pedal to start the car:
"Unable to drive - Authentication required"
Has anyone else seen this? When this happens I manually unlock the doors by double clicking the fob and while still seated on the driver's seat I open and close the driver's side door and the car turns on when I subsequently press the brake pedal.
This also seems to affect being able to sometimes walk up to the car and open by the trunk just by pressing the button. I need to manually double click the trunk button to open the trunk when it happens.
Is this a low battery issue with the fob? I thought there was a specific low battery alert if the key fob battery is low.
I did Google this error and I only found one single passing reference on TMC so this seems like an odd error. I appreciate any insight on what is causing this.
