What they have on the Model 3's in China is the same as what they have on new S & X in China. GB/T AC plus GB/T DC.The standard that Tesla is going with in China is GB/T, which apparently is being combined with ChaDeMo into a new GB/T fast charging standard. The new GB/T standard will be backward compatible with ChaDeMo, so let's hope Tesla skips to either a new GB/T standard adapter or offers a new dual GB/T and Tesla port, which is what they have on their Model 3s in China already.
Tesla vehicles that already have the capability to use ChaDEMO actually using was relatively rare to start with, due to requiring $500 hardware (people would borrow the gear from local "clubs", informal or more organized, when they were going to do a long distant trip to certain areas). Use even when you have the hardware is becoming rarer, because the motivation (need, convince, or desire based) is continuing to ebb away.
you're missing a major use case
Are there workplaces putting in L3 charging?workplace level 3 charging.
My current employer actually just sent out a survey concerning workplace charging and L3 was an option listed. My previous employer has 36 L2 recharging spots that were always in use by several hundred electric and hybrid cars. If they had L2, a lot more cars would be able to charge throughout the day.Are there workplaces putting in L3 charging?
I don't see how L3 charging at work would be a major use case. More L2 charging is less expensive and more convenient. Better to just plug in and charge when at work, and unplug when you leave work.
I think a better workplace configuration would be on 3p480 service with 4 Wall Connectors (or J1772 equivalent) per circuit on each leg of service (277v). Each 100amps of service could power 12 L2 connections (66kW at 80% circuit loading). Over 8 hours that would provide an average of 44kWh per vehicle, which seems more than adequate. The alternative would be two 33kW L3 (probably more costly), where people would have to shuffle cars during work.
You could even have some "fast" L2 connectors where they are configured 2 connectors per circuit, so 22kW would be shared by two cars to deliver 44kWh average per vehicle in 4 hours.
It will be interesting to see the results of the survey. It seems to me the charging capacity is limited by the kW made available to the chargers. If there is 66kW spread across 12 L2, or 2 L3, that is the same daily charging capacity. My guess is installing and maintaining 12 L2 is less expensive than 2 L3, but that is just a guess.If they had L2, a lot more cars would be able to charge throughout the day.
You're right, and yet wrong, mainly because you're missing a major use case that Tesla has not been able to address, and a use case that has the potential to result in a lot of sales, both of CHAdeMO adapters and cars: workplace level 3 charging.
Which would be more convenient for you - to have enough L2 spaces for all cars, or have an L3 for every 6 cars?
That would make sense. I'm glad companies are starting to think this way.It sounded like they were considering a combination of L2 and L3 charging stations.
My 3 will be here Friday That said there are no superchargers opening here. The closest is a 35+ min drive with the next closest 70min away. Even destination chargers don't seem to get a cross the bridge.
We do have a number of ccs fast chargers though.
Unless you don't have the ability to charge at home.You would never use one near your home.
