Although I'm impressed with the mathematicians in here and I like some of the info you guys are coming up with, let's consider the following.
1) Tesla advertises the P85D as 691HP. The S85 is advertised at 380HP, and the S60 is also advertised at 380HP.
2) There is little to no difference after 50MPH in acceleration across the P85D/S80/S60 fleet. Therefore advertised 691HP on the premium performance model is non-existent vs other models in the fleet. MORAL OF STORY: ADVERTISED 691 HORSEPOWER OF P85D IS ONLY TEMPORAILY AVAILABLE AT LOWER SPEEDS. In an ICE car, advertised HP is available AT ALL SPEEDS, but dependent on RPM - but you have all HP on tap at any speed (dependent on correct gear)
3) When fuel tank is low (battery) on P85D, performance suffers versus full tank (full charge). ICE vehicles don't care about the current level of fuel in the tank.
4) Since EV's peak horsepower seems to only work in a burst mode/temporary spike at low RPMs, why is Tesla able to advertise 691HP in the way a standard auto manufacturer rates an ICE vehicle? If a Corvette only outputted it's maximum advertised HP from 0-30MPH, and after that the same as a Camaro V6 with half the advertised power, the shat would hit the fan! There is a huge issue with how the P85D's 691 advertised HP is being marketed. I DONT CARE if it puts out slightly less peak HP then advertised, no big deal as the 0-60 times and a 5,000lb car speaks volumes - but this CAR DOES NOT OUTPUT 691HP AT ALL TIMES, ONLY WHILE UNDER 30MPH AND ONLY WHEN FULLY CHARGED. Hence, the reason I recommend Tesla puts an asterisk next to the advertised power because that power is ONLY ON TAP FOR SHORT LOW SPEED BURSTS.
