smorgasbord
The graph shows the deeper the discharge, the lower the number of cycles.
Isn't the graph predicated upon fully charging the battery and then discharging to the the specified DOD? In other words, charging to 100%, then driving to 90% versus charging to 100% then driving to 80%, etc. If so, that's not what happens when someone charges to 50% and drives to 40%.
That graph is all over the web, but I can't find where it originated. I found this informative link, though. It has that same graph and says about it:
The above graph was constructed for a Lead acid battery, but with different scaling factors, it is typical for all cell chemistries including Lithium-ion. This is because battery life depends on the total energy throughput that the active chemicals can tolerate.
They compare some examples from the graph:
the total energy throughput is fixed so that one cycle of 100% DOD is roughly equivalent to 2 cycles at 50% DOD and 10 cycles at 10% DOD and 100 cycles at 1% DOD.
Furthermore, at this link, they say:
A more representative measure of battery life is the Lifetime Energy Throughput. This is the total amount of energy in Watthours which can be put into and taken out of a battery over all the cycles in its lifetime before its capacity reduces to 80% of its initial capacity when new. It depends on the cell chemistry and the operating conditions. Unfortunately this measure is not yet in common use by cell manufacturers and has not yet been adopted as a battery industry standard. Until it comes into general use it will not be possible to use it to compare the performance of cells from different manufacturers in this way but, when available, at least it provides a more useful guide to applications engineers for estimating the useful life of batteries used in their designs.
If that's true, then drawing from 50% to 40% isn't worse than drawing from 80% to 70%, since both draw the same Watthours.
But, then again, we know this isn't the only factor. Charging level is also important. There this graph:
It show that reducing the charging level (done by reducing the charging cutoff voltage) extends the number of charging cycles that can be obtained. Tesla talks about this on their blog. I think that's what people are hoping to leverage by not fully charging the battery (or not even charging to Tesla's Standard Mode 87% charge).
However, we know that pulling lots of power from a battery with a low charge is also bad for the battery. I believe that's one reason Performance Mode charge charges the battery to a higher level (another is simply to help the range out). So, if you're doing the Storage charge all the time thing, you might want to drive in Max Range mode to avoid over taxing a low charged battery.
I agree with Scott451 that we should do what Tesla recommends and not try to game the system leveraging factors we don't fully understand and have not tested. There are interactions that aren't covered by published theory and I believe one is more likely to make things worse than better.
