SpudLime
Also, this member did a great post about some of the things he noticed when using the dash cam.
Software Update 2018.39.5 a1c2332 (first 9.0 release)
It only mentions 1.8 GB for the hour rotation, so that doesnt allow for when you hit the keep button to keep the last 10 minutes.
FAT32 can have file sizes up to 8GB and single volumes up to 8TB - at least for a regular drive. I believe a USB stick is the same.
Some computers/devices have limits reading large drives/usb sticks... but the format works. I have found problems with some older cameras.
Thanks @SpudLime . Looks like I'll need a larger USB!
Yup. Think your right. My memory sucks. Thanks! In any case, the volume limit is pretty large.
For anybody thinking of putting the TeslaCam folder on your music usb, don't do it.
v9 seems to search for TeslaCam first and when it finds it, that usb drive can not be accessed by media player.
I wonder if Tesla did it that way because of the slow USB read/write speeds.
@hulk2k17 try resetting the MCU/touchscreen (long press of both roller wheels). I’m not sure entirely, but that helped my car on one of my many USB removal/reinstall attempts.
New issue. After removing the USB, then re-installing it in the car the icon remains “normal,” and it appears to be on and recording. Checked it later and it had in-fact recorded nothing for over and hour of driving. Zero files saved.
Uggg
So the I have the same problems that you guys have seen. I plug in a USB flash drive and it works for awhile, but as soon as I pull it out, view a video or two and plug it back in, it decides to stop working. "
Same problem here. Brand new 128 Gig pre-formatted FAT32 Drive. Worked at first, removed to examine files... no longer works. Will try reformatting, but this should NOT be the default behavior.
Having issues with my dashcam. I got it to work but it seems to write files every minute to the USB drive for an hour. The problem is that it is writing files to the drive when the car is charging in the garage? I used the car last night returning at 10PM, October 13th. The USB has files every minute from 11:48 to 12:40. It also has the dates wrong, the 11:48 file is labeled 10/14 and this changes to 10/15 for the files written at 12:00 and after - even though it is still 10/14 today? The files are just the view of the inside of the garage in the dark. I expected to see the last hour I was driving the car? Anyone else having similar issues?
