Though I always felt this idea was common sense (and should have been done with the tranny change), it certainly looks like it. :smile:This dash finally makes sense. Somebody at Tesla is surely reading this forum
Tachometer should be joined with speedometer with a single needle. Instead of existing tachometer there should be "powermeter", showing current engine power usage.
>> I feel that the change to the single speed trany has made the tach useless.
I'm still rooting for it to be replaced by a powergauge with some negative field for regen. Maybe an aftermarket mod? :biggrin:
Something like this:
I might try the KW gauge with the TDC as the zero point.
Can you put the negative numbers into green? Or maybe it should just be the curved scale markings - like the red section for 180 and 220?
TEG said:On the Highlander Hybrid they don't bother with an RPM gauge because you have both eMotor and Gas Engine sometimes working alone and sometimes working together.
Instead they have a tach like thing that shows total system power (in kW) being created.
Yes, it's an obvious sensible thing to do. I was just pointing out that even finer details like those suggested by WarpedOne ("tachometer should be joined with speedometer with a single needle"), vfx ("KW gauge with the TDC as the zero point"), and malcolm (green scale markings) appear to have been implemented. Credit goes to the forum. :smile:I had been pushing that idea for years now...
http://www.teslamotorsclub.com/tesla-model-s-whitestar/383-whitesstar-dashboard.html#post2175
Credit goes to WarpedOne for actually mocking one up on the Tesla panel!
Whenever I see something like this I think: "necessity is the mother of invention." In other words, if something is needed then lots of people will be coming up with ideas and the more necessary the feature the more likely more than one person will have the same or similar implementations.Yes, well, it is hard to know how much influence (if any) we have on their decisions. Probably at least a little bit of idea generation, but much of the time I think we may just be "thinking logically" and coming up with ideas that they would have done anyways.
