Kutu
Is this program still working? I am not able to log in (Windows Package ) and I am sure i have the right credentials.
I can't get in either. The iPhone/iPad Tesla app works fine.
I reinstalled OpenJRE from the software library and it must have also installed a proper launcher this time sine I at least get to JavaFx launcher which informs me that In need a newer version of Java (ugh!). I think this message if from VisibleTesla itself which somehow doesn't recognize OpenJRE as valid.
I'm trying to run VisibleTesla 0.50.08
Has anyone else had problems with the Trips tab not showing data at all? I've got a brand new 90D so I'm sure there are some differences, but everything else seems to work fine (climate control, charging, etc) but trips doesn't show any data at all. (This is using the latest release: 0.50.8)
This usually means that it could not connect to X11, i.e. it tried to create the GUI but failed to do so.Thanks very much. I think I'm making progress.
However, now get Exception "AWT-EventQue-0" java.awt.HeadlessException
at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:207)
I'm running Xubuntu 14.04 LTS with java -version 1.7.0_79
OpenJDK Runtime Environment (IcedTea 2.5.6) 7u79-2.5.6-0ubuntu1.14.04.1)
OpenJDK 64-bit Server VM (build 24.79.-b02, mixed mode)
First, Oracle really doesn't want you to use Java 7... they make it very hard to find and install.
Mine doesn't show any trip data too.
There are a couple of subtleties to this tab.
I hope this helps.
- You need to click on a specific date (or range of dates) on the calendar and it will then show the trips for that date range. Until you pick some dates, nothing is shown.
- If you have recently (like within a few minutes) completed the trip, VT may not have identified the trip as completed. In that case, click on the end trip button to force trip completion of the most recent trip and add it to the list of completed trips.
While the trip tab is a bit confusing at first, I can confirm that, in my case at least, the data is actually not there. Any date that has a trip turns a green color, but on mine none of them show up as having any trips at all. I can manually click into individual dates or select the entire month of September, and it still shows 0 trips. The data is just not there.
I'm wondering if maybe something changed with the new models (mine is a brand-new 90D) that prevents the trip data from being downloaded.
Is it possible to determine if there is a pending SW update in VT?
I do not believe so. If there is, I haven't figured out how to do it.
That is for checking for updates to VT, not for updates to the car...In the Mac version (0.50.08), there is a "Check for Updates" at the bottom of the Help menu.
Is this even possible? How does the iPhone app know of a pending update when it notifies the user?
Keep in mind that Tesla hasn't published their API. Everything that VT does was reverse engineering the API. The update avail notification either hasn't been reverse engineered, or if it has, hasn't been incorporated into VT yet...
Does Remote S also push this notification? If so, perhaps Allen would share the required API information with Joe.
