On the drive home from Fremont delivery, the car was very quiet. So I was surprised to hear obvious rattling sounds on subsequent drives. After investigation, I found it is coming from the sun visors, only when they are placed in the down (deployed) position. When used, the end of each visor rattles in its plastic retaining clip since it is not held tightly. A workaround is not to use them (when they are folded up to headliner they no longer rattle), or to unclip them when down. It is perhaps exacerbated by the stiffer suspension and is a lot worse on bumpy roads. I’ve added to list for next service visit and it is actually not the most annoying issue (which is inability to route in the nav to home addresses). Wanted to see if others have experienced the same rattle issue or if this appeared with the 2018 headliner change.
