OR install a NEMA 6-50R those adapters are almost always in stock at Tesla, and there should be no cost difference to install it. This is a standard plug at many RV parks and rest areas and offers a rarely discussed way to charge in a pinch.
Or even for daily home charging. Good suggestion.
- Perhaps fewer people will have that kind of cable/plug handy, so an outdoor NEMA 6-50 receptacle is perhaps slightly more secure from undesired tampering/use?
- It lacks the neutral line, I guess. Is that a concern?
- With a properly installed NEMA 6-50 receptacle (heavy duty Hubbell/Bryant or equivalent receptacle; 50-amp GFI breaker; #6 or heavier house wire) a Tesla Gen 1 Universal Mobile Connector (no longer available from Tesla) with proper lock-on NEMA 6-50 adapter ($45 from Tesla) should allow continuous charging at 40 amps (just like when using the lock-on Gen 1 NEMA 14-50 adapter plugged into a properly-installed NEMA 14-50 receptacle).
- However, the newer Gen 2 Mobile Connector ($275 from Tesla) with proper 6-50 adapter ($35 from Tesla) would charge at 32 amps, I imagine (like with its NEMA 14-50 counterpart).
- Are there aftermarket connector cables/adapters with NEMA 6-50 adapter plugs (but lacking Tesla's built-in safety handshake circuitry?). (A quick Google check suggests, yes there are.)
- The only Tesla charging accessories for a 6-50 receptacle that are lacking are a one-piece connector cable (equivalent to the Gen 1 Corded Mobile Connector) and a 6-50 plug-in wall connector. (But a to-be-hard-wired wall connector could be properly/safely modified to plug into a 6-50 receptacle, correct? Though I am a little unsure why one would bother to do that.)
