Since someone resurrected this thread, thought I would just chime in. I did NOT switch to a Lithium flavor of battery for the 12v. After learning much more, and some own "home" experiments etc...
One of the MAJOR factors in this decision, is due to charging of the Lithium battery. I'm not going to go into major details in this thread as it's been talked about to death already, however, Lithium batteries have a "happy place" in terms of Temps they like to be kept at, especially during charging.
They must be above freezing (33*F, 1*C or higher) or the lithium cells will internally electroplate resulting in permanent capacity loss during charging. And they like to be kept below 113*F. Charging or having high state of charge at or above this starts to exponentially increase rate of degradation.
While a Lithium drop in in a more, southern or temperate climate might do "Fine" like some roadster owners are experiencing, here in Wisconsin, where we are below freezing for a nice portion of the year, let alone those further north of us..... Would require a 12v battery heater. This would consume battery power, needing the contactors to be closed from the HV pack to charge the Lithium battery more, wasting much needed winter range. I decided against this.
As for those using Shorai batteries , that are anything other then the most recent, I warn much caution. They had a MASSIVE recall on the batteries due to faults causing meltdowns. No fires due to the chemistry used, however, a meltdown can get fairly ugly in a confined space such as, in a car.
